-   -   Steering noise (http://forums.pelicanparts.com/porsche-911-technical-forum/673211-steering-noise.html)
Hubberth 04-21-2012 09:43 PM
Steering noise
When I hit a bump or turn the wheel back and forth there is a clunk sound from the lower steering shaft or from the steering rack. What should start looking for? U-joints?
Thanks Neil http://forums.pelicanparts.com/uploa...1335073378.jpg
DRACO A5OG 04-22-2012 12:08 AM
Check your lower and upper U joint, it may have come loose. Do not over torque the nuts.
If that does not solve it, one may need replacing.
Hubberth 04-22-2012 07:39 PM
Thanks I'll check it out.
Hubberth 07-09-2012 05:25 PM
Just checked it out both bushings in rack have come out. What the He..? circlips, snap rings
what holds it together?
