When I hit a bump or turn the wheel back and forth there is a clunk sound from the lower steering shaft or from the steering rack. What should start looking for? U-joints?
Thanks Neil
Member 911 Anonymous
Check your lower and upper U joint, it may have come loose. Do not over torque the nuts.
If that does not solve it, one may need replacing.
'85 Carrera Targa Factory Marble Grey/Black * Turbo Tail * 930 Steering Wheel* Sport Seats * 17" Fuchs (r) * 3.4 * 964 Cams * 915 * LSD * Factory SS * Turbo Tie Rods * Bilsteins * Euro Pre-Muff * SW Chip on 4K DME * NGK * Sienes GSK * Targa Body Brace PCA/POC |
Thanks I'll check it out.
Just checked it out both bushings in rack have come out. What the He..? circlips, snap rings
what holds it together? |
