Born to Lose, Live to Win
ramonesfreak's Avatar
Inner tread wear on front tires only
Both my front tires are worn on the inner edge...both tires have about the same wear at the inner edge..the rest of the tire is worn evenly
I am going to replace these tires next week and want to take the car to my mechanic and have this addressed so that I dont ruin my new tires the way I did the current ones...only got about 15K miles out of them
Im trying to figure out the budget for this fix....
is this an alignment issue?
Sorry no photos at the moment
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 05-07-2012, 05:44 PM
docrodg's Avatar
Probably an alignment issue. Inner tread wear is indicative of too much negative camber.
1968 911S "Leona"
Air goes in and out, blood goes round and round, any variation on this is a bad thing.
Old 05-07-2012, 06:00 PM
was thinking negative camber but wasnt sure if that could be corrected with alignment. Thanks
1983 911sc
Old 05-07-2012, 06:02 PM
SCOTITUDE's Avatar
Send a message via AIM to SCOTITUDE
camber is one of the things an alignment will correct.
1980 911SC #99 track car, 993 3.6, 50 PMO's
2019 Ford F150 da dragger
2015 MB SL400 wifey DD
2008 E93 M3 DD
2007 E60 530 wifey winter beater
Old 05-07-2012, 08:14 PM
midnight911's Avatar
likely toe out...
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 05-07-2012, 08:51 PM
Originally Posted by midnight911 View Post
likely toe out...
x2
Too much negative camber can cause inner tire wear, but I find too much toe out is more common.
Old 05-07-2012, 10:11 PM
Member 911 Anonymous
DRACO A5OG's Avatar
+3 Too much Toe out
'85 Carrera Targa
PCA/POC
Old 05-07-2012, 10:24 PM
redturbo911's Avatar
Alignment Im thinking.
Tony
91 964 c2 black/ Work in progress/Finally back on the road
85 EURO 930 Black slightly moded slowly reviving her
77 911tt EFI wide body red/ Slightly modified SOLD
Old 05-07-2012, 11:00 PM
MConn's Avatar
My fronts are also worn in the inside, with a lot of tread remaining on the outside. I'm not sure if its caused by bushings, but I've decided to replace the A arm bushings and camber plate bushings with Elephant racing rubber. My 1987 model A arm bushings had significant distortion.
Old 05-08-2012, 06:03 AM
It's a combination of too much toe out and negative camber, but the important question here is, what kind of tire is it? 15K is a lot of miles for a set of high performance tires on a 911.
Old 05-08-2012, 07:02 AM
Fleabit peanut monkey
Bob Kontak's Avatar
likely toe out...
Wouldn't there be some scrubbing showing also?
As well as what you ask from you car. :-)
I am with the negative camber vote.
Alignment will fix either/both and you do not need to get a $400 weight balance alignment unless you choose that. The guys at alignment shops are not baffled by the 911 suspension. Do look for an established place that does mainly chassis work and has some lifer wrenches vs. big box repair shops that hire 19 year olds right out of tech schools. Kids are sharp, no doubt, but experience requires screw-ups.
Old 05-08-2012, 07:53 AM
na2ub's Avatar
While it could be toe out, you would probably know about that condition as the car would "wander" on the highway.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 05-08-2012, 08:04 AM
I don't think I've ever gotten 15,000mi. out of a set of tires maybe 10k. Always check your alignment when you change tires.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 05-08-2012, 08:10 AM
