| lendaddy |
05-03-2002 05:46 AM |
Oh, your gonna like this. Wrong rotor?
For the last week I have been trying to get my baby running after a major tuneup right. I ordered all my stuff from Pelican. I went to the MSD 6AL with the rev limiter. My car originally had the rev limiting rotor installed (7,000 RPM, which seems high to me anyway) and I no longer need it due to the redundant MSD unit. So I tell Pelican that I want the standard non rev limiting rotor for my application no problem right? Wrong, If you look at the pictures of a rev limiting rotor the pickup point is in a different location than the standard rotor. Assuming that a normal straight rotor has the brass contact at 12:00 based on the key on the shaft, the rev limiting version is at maybe 1:00-1:15. There was not enough movement in my distributor slide adjustment to compensate for this. Whats more, I did not even want to play with the distributor for the first 2-3 days cause I knew it was right when I put it away and I did not want to add another variable to the situation until I had it pretty well buttoned up. Now I can hear you saying why didn't you see this when you swapped them out, well I removed everything the day before I got the new ones so there you go( yes,I did enjoy digging thru the trash to find the old one last night). It still isn't running great but I believe that is a vacuum issue because I also found out that the 3/4" lines to the WUR are actually vacuum lines and the silicone lines I ran suck flat right away and the vacuum at the distributor is present but not very strong. So I am getting there. As a side note our tach's are voltage regulated if you have been following my posts at all you know what thats about.
