Remove torsion bar from radius arm...
Anybody got a tip how to remove the torsion bar from the radius arm? It's on really tight and don't want to damage the torsion bar !
Appreciated! Erik
There are a few similar queries on here, but the end cap of the arm is replaceable so just drill a hole in it, remove the end cap and punch the torsion bar out of the arm. Get a new cap.
Regards Ian |
Cool!
Thanks!
Will put in a search first next time.....Sorry. |
Hold bar with vise grips then rap the spring plate with a hammer it will wiggle off.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
The only way i could get mine off was with a puller and LOTS of heat.
Not my picture but that's what i had to do. Hope yours come off easily.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Just did mine today... Pop the cover, puller, WD, and heat.
Why don't these things get put together with anti seize?! I wouldn't use vice grips if your planning to reuse it. The most stress in a torsen bar is on the surface. Notches, even in non-notch sensitive material are bad juju .Just be thankful it wasn't the other end that got stuck! tadd
1967 912 with centerlocks… 10 years and still in pieces! |
I don't have advice for hard to remove spring plates, but from this tread and others with various methods that have been used, it seems they can in instances be very problematic! I just thank my luck in having mine wiggle off very easily using only my hands. Maybe having a California car has something to do with it?
Dave '75 911s Coupe |
Wow I guess I got lucky today. Drilled the cap and took a punch and hammer to it. All set and done in less than 30 min for both.
you just missed an opportunity to upgrade your torsion bar...
1984 911 Carrera Coupe - 32C #73 - M64/05 1998 E36 M3 4dr 2006 Sienna 5dr - the hauler 2004 Lexus GX470 2010 Cannondale Caffeine II - Lefty |
there is a pic in this thread, someone responded to my question not long ago.
T-Bar Stuck in Spring Plate - Help!!
Fat butt 911, 1987 |
