Honey Badger
theFONZ's Avatar
Engine/trans Jack Removal Adapter Question
Can someone that has one of these tell me if the post that inserts into the jack is removable, and possibly post a pic? My jack has a smaller hole than the 1 3/16 that the description says it needs. I'm wondering if I can either switch to a smaller size post or modify it some other way.
Thanks!
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 04-29-2012, 06:29 PM
Porsche Crest
It is welded to it.
Old 04-29-2012, 06:55 PM
Honey Badger
theFONZ's Avatar
Crap. I don't wan't to have to cut it off if it's welded. I guess I'll have to make something or use my hoist.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 04-29-2012, 07:04 PM
ROW '78 911 Targa
timmy2's Avatar
How much of a difference are you talking about? I had to take a little off of mine all the way around the post with an angle grinder to get it to fit my jack. Took about 10 minutes.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 04-29-2012, 09:12 PM
Honey Badger
theFONZ's Avatar
About a quarter inch. I don't really want to grind that much.
My jack has a 22mm threaded plug that holds the jack pad on. I'm wondering if I could cut the post off and drill a hole to use the threaded plug to hold the adapter on. How difficult does it look like it will be to remove the post?
If it won't work, I'll figure out how to use my hoist instead.
1978 911SC
1953 Piper PA-18A
USAF EOmfD
Old 04-29-2012, 09:27 PM
ROW '78 911 Targa
timmy2's Avatar
I made the choice to keep the threaded portion on the jack pad as I like to be able to adjust the height of the pad. You could just grind/cut the post off flush and weld a different one on that fits. About an hour's work at a good weld shop if you need it done for you.
If you were a little closer I'd just loan you mine.
Dennis
Old 04-29-2012, 10:18 PM
