Cam lift .377 inches
I have a cam that has a total valve lift .377 inches, or 9.57mm, Im trying to do cam timing, but my cams are not stock, can anyone tell me what cam this is and what the cam timing measurement should be.
thanks eric |
Irrationally exuberant
And they engine would be???? (might be helpful to specify the engine or at least the car year).
-Chris |
The engine is a 73' 2.4 motor. Registered as a "T" motor, but not sure.
Eric |
Eric,
That value is 0.01" below what a new 'T' cam spec is ... of course it may be that your rocker ratio isn't exactly 1.5, too! Did you measure the intake lift for both cylinders #1 and #4? I think you need to measure the exhaust valve lift for both cyl. #1 & #4 to be sure!
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
