rrental's Avatar
Remove torsion bar from radius arm...
Anybody got a tip how to remove the torsion bar from the radius arm? It's on really tight and don't want to damage the torsion bar !
Appreciated!
Erik
Old 04-29-2012, 11:57 AM
There are a few similar queries on here, but the end cap of the arm is replaceable so just drill a hole in it, remove the end cap and punch the torsion bar out of the arm. Get a new cap.
Regards
Ian
Old 04-29-2012, 12:00 PM
rrental's Avatar
Cool!
Thanks!
Will put in a search first next time.....Sorry.
Old 04-29-2012, 12:04 PM
kodioneill's Avatar
Hold bar with vise grips then rap the spring plate with a hammer it will wiggle off.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 04-29-2012, 12:15 PM
pete3799's Avatar
The only way i could get mine off was with a puller and LOTS of heat.
Not my picture but that's what i had to do.
Hope yours come off easily.
Pete
79 911SC RoW
Old 04-29-2012, 12:26 PM
tadd's Avatar
Just did mine today... Pop the cover, puller, WD, and heat.
Why don't these things get put together with anti seize?!
I wouldn't use vice grips if your planning to reuse it. The most stress in a torsen bar is on the surface. Notches, even in non-notch sensitive material are bad juju .
Just be thankful it wasn't the other end that got stuck!
tadd
1967 912 with centerlocks… 10 years and still in pieces!
Old 04-29-2012, 02:52 PM
I don't have advice for hard to remove spring plates, but from this tread and others with various methods that have been used, it seems they can in instances be very problematic! I just thank my luck in having mine wiggle off very easily using only my hands. Maybe having a California car has something to do with it?
Dave
'75 911s Coupe
Old 04-29-2012, 03:47 PM
rrental's Avatar
Wow I guess I got lucky today. Drilled the cap and took a punch and hammer to it. All set and done in less than 30 min for both.
Old 04-29-2012, 09:09 PM
midnight911's Avatar
you just missed an opportunity to upgrade your torsion bar...
1984 911 Carrera Coupe - 32C #73 - M64/05
1998 E36 M3 4dr
2006 Sienna 5dr - the hauler
2004 Lexus GX470
2010 Cannondale Caffeine II - Lefty
Old 04-29-2012, 09:18 PM
rnln's Avatar
there is a pic in this thread, someone responded to my question not long ago.
T-Bar Stuck in Spring Plate - Help!!
Fat butt 911, 1987
Old 04-29-2012, 11:04 PM
