-   -   HELP! 915 Trans 5th gear upgrade problem, Peter Zimmerman or other guru please help! (http://forums.pelicanparts.com/porsche-911-technical-forum/675695-help-915-trans-5th-gear-upgrade-problem-peter-zimmerman-other-guru-please-help.html)
uwanna 05-03-2012 10:43 AM
915 Trans 5th gear problem
Never mind :) Decided to stay with standard 5th gear.
john walker's workshop 05-03-2012 02:34 PM
never experienced that, yet. that's a pretty high ratio. i hope it doesn't lug at freeway speeds. i have a 0.72 in mine and the shaft fits. about all you can do is have it ground out, unless powerhaus has the proper shaft.
uwanna 05-03-2012 03:37 PM
John,
changed my mind on the 5th gear, think you are right, the ratio is awfully high. Where did you get your 0.72 gear. Would like to find an 0.72 set, any thought on where to get one? Also, what is number of teeth per gear, and the Letter designation of that gearset?
john walker's workshop 05-03-2012 06:33 PM
it's from a 1976 912E trans. tooth count, i'd have to research.
Peter Zimmermann 05-03-2012 06:36 PM
Sorry, couldn't access the site!
The 5th speed for a '76 912E is a 29/21, which gives you .7241. This 5th speed is designed for a R&P ratio of 7:31, and an absolute slug of an engine!
