pensacola mike's Avatar
Porsche Crest What does this connect to?
Hello, I'm hoping for a little help. I have been trying to track down an electrical gremlin in my 87 911 coupe as to why the front parking/turn signals do not work but rear are operational. I have been looking around and found a few loose wires. I don't quite have the hang of how read the electrical schematics found in Bentley's manual. so I hope someone can tell what these are and what I should do with it?
Old 05-06-2012, 06:41 PM
aualexa2's Avatar
Where are the wires located?
Old 05-06-2012, 06:56 PM
They trail along the front bumper.
Old 05-06-2012, 07:09 PM
The plugs in the first photo are for the fender oil cooler fan and thermostat. It looks like a relay should be plugged into the socket in the second photo. I think the missing relay is for the headlight washer pump.
Old 05-06-2012, 07:31 PM
Thanks for your help, my car currently does not have headlight washers on the bumber. So would the car have been built with wiring in the event of an upgrade?...
Old 05-06-2012, 07:42 PM
Could be. Check out this thread. Is this where that socket was located?
Headlight washers. Can I remove this pump?
Old 05-06-2012, 08:09 PM
Do you still have the fender oil cooler and fan in place?
Old 05-06-2012, 08:31 PM
I don't have the pump. And only have a trombone cooler under the front passenger wheel well
Old 05-06-2012, 09:39 PM
