bigfishassasin's Avatar
Spacers for ruf wheels on converted turbo look 911
I need spacers for my Turbo look 911...the wheels are ruf speedlines. My car started life as a 1978 SC and all parts are factory to that year. Any help would be greatly appreciated.
Rob
Old 04-24-2012, 04:09 PM
Oh Haha's Avatar
We need to know the offsets of the RUF wheels to give you an answer.
Pacific Blue
Wayne
Old 04-24-2012, 04:39 PM
Thanks Wayne...I'll need to go to the shop to get that info and its an hour away. So hopefully by Saturday
Old 04-24-2012, 05:06 PM
If the Ruf wheels are the later offsets (ET50ish or so), you're going to need some gigantic spacers! I have a widebody '80SC convert, and have 17"x9" ET15 wheels, and needed 2" spacers to move them out to fill the rear fenders. With ET 50ish wheels, you will need a bunch more than the 2" to make them work. I think you'll need another 1.5", giving you a a 3.5" spacer to use the later offset wheels, and that's one hell of a spacer! If the Ruf wheels are for the earlier offset ie.ET15, all you will need is a 2" spacer. I really don't
know what you will need in the front.
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 04-24-2012, 05:21 PM
petercory
I'm running 8's & 9"s with 13mm Spacers in the front and 35mm Spacers in the rear which fill out the wheel wells nicely
Old 04-24-2012, 07:17 PM
Ok guys I have the offsets
Fronts 17 x 9 ah e=17.7
Rears 17 x 10 dl e=5
The wheels are on the car and surely I'm gonna need spacers both front and rear. Need them before the weekend so we can test drive the car.
Old 05-07-2012, 09:06 AM
Old 05-07-2012, 09:14 AM
Looks like you have "early offset Rufs". Looks just like my widebody '80SC conversion before I added 1" spacer in front and 2" spacer in the rear.
Old 05-07-2012, 09:26 AM
Do you have the 17 x 9 and 17 x 10 on your 1980? Because i need to order some spacers quick.
Old 05-07-2012, 12:28 PM
otto in norway's Avatar
I think I'm using 43mm in the rear, and about 24mm in front. About 99% certain. (From memory)
I got the 9x17 ET17,7 in front, and 10x17 ET5 on rear. These rims are about as far out as you can get them. Meaning if you got soft suspension and wide tires, you may have clearance issues.
Old 05-07-2012, 01:19 PM
I have 17x7.5 ET23 front and 17x9 ET 15 rear with 1" spacer front and 2" spacer rear.
Old 05-07-2012, 02:49 PM
Now I have checked what others are using, and I am no longer so sure about my offset on my wheels... Sorry!
Old 05-08-2012, 03:27 AM
