I went with an MSD because I've been using it for over 20 years with zero problems I didn't create myself.
I'll let the dieing dog die now... |
ON A DYNO...WIDE OPEN THROTTLE...FULL ENGINE LOAD. And the twin plug mode indicated a 15HP "gain". |
So why did you send your box to him... if you know all about this issue, then we should all be sending our box to you not Loren... and you def should not be sending yours to Loren. If you can pull a Bosch Schematic off Google, then you should be able to at least repair your own box. geez.
Im out on this thread. Good luck. Quote:
Why is it that you don't address the questions I ask of you? Maybe because you don't have a clue about the need for twin plugs in a high compression 911 engine? |
Correct. We/Mike Bruns ran the engine with single plug (one MSD) to set a base line. Tuned it to that (remember I have Webers), then hooked up another MSD to the bottom plugs, reduced the timing to 28degs and ran it some more. The result was 15 more HP.
I thought about running the twin plugs with one MSD and two coils but after conversations with Mike, MSD and Mallory I decided to run two MSDs thru two coils just in case there was a marginal benefit . I didn't like the idea of mounting the MSDs in a remote location. I looked around at different mounting locations. Since I was moving from Florida to Oregon I felt that heat would not be an issue. With a little experience in Electronics before I changed my career to flying I elected to mount the MSD units on top of each other in the engine compartment where the old CDI unit was. I like the idea of short wire runs. |
Yesterday, after I wrote the dessertation on the Bosch CDI, I took it and the schematic to those engineers to check and be sure my analysis of the operation was correct. Only one point was left outstanding. It is my point, theory, that once the spark extinguishes the remaining magnetic field within the coil will partially recharges the ignition capacitor as it continues to collapse to nil. There was no disagreement on that point, just lack of assurance of my theory. O'scope proof, come Monday. Even today, when the need for analog circuit design, electronic circuit design, comes up, I remain, still, the go-to engineer for my company. Air conditioning. Back in '69 when I first become involved in computer system design, it was almost always the case that some method of cooling the beasts was required. As it happens my choice of market area for my computer designs, useage, was automation of some of the operational aspects of pulp/paper mills and sawmills througout the Pacific NW. How did you get a minicomputer to operate reliability out on the floor of one of these mills...you isolate them from that extremely HARSH environment. So as an integral part of our installations we provided a computer cabinet, somewhat sealed, with an A/C evaporator/fan integral to the cabinet design (Heat Controller, Jackson, Michigan). Split system, with the compressor/condensor located elsewere, remotely. We soon discovered that the A/C computer cabinet design was also viable in the commercial market, in areas wherein an actual cooled computer room was not an option. But my earliest A/C experience involved the design of the chiller system used to cool the "stable-table" with the guidance head of the minutemen missile itself....'61. I still keep in touch with a few of the team engineers for that project and rely on them for guidance when the need arises. |
That was a joke/pun....or was it......? |
Thread summary:
1) CDI boxes will create sparks and run the ignition system of a 911, there are many options. 2) One high voltage CDI (MSD,etc.) will fire two plugs in one cylinder with slightly reduced spark energy. 3) Two CDI boxes will fire two pugs in one cylinder with maximum spark energy. 4) Multiple sparks--- MSD has them. Oh, and Ferrari as well. 5) Isn't it great we have so many options for fueling, sparking, and personalizing our 911s? |
You are proven incorrect numerous times in almost every thread you post in... and you never answered my question...
If you are the resident expert on Bosch CDI, then why did you send yours to Loren, a guy you say is clueless, to repair yours? I smell BS. Oh and "dessertation" is spelled "dissertation"... Quote:
wwest
Perhaps you should read thoroughly through the post and understand what was said before twisting the information for your arguments. If you read the statements made by Kent he clearly states that the difference of 15 hp was a direct correlation between a single cdi unit firing a single plug and dual cdi units firing two plugs. Nowhere was there a correlation between one cdi unit firing two plugs and two cdi units firing two plugs. There is no definitive correlation of how much HP would be lost if he was to use only one cdi unit for firing dual plugs. That test was never carried out on the dyno. There was only a statement made that there would be a slight loss of power using one cdi unit to fire dual plugs. How much is a slight loss, 2-5 Hp or more nobody knows as this was never determined in the testing. Quote:
Exactly. Which is why this whole discussion is so pointless. We are dealing with a few bloviating buffoons.
Perfect Summary. Thanks.
We were able to limp him home via unplugging the VR until the battery became to low to operate the car, then plugging the VR back in, etc, etc. We inadvertently, wrongly, decided the problem had been a bad battery and then the car was subsequently not driven often enough, or long enough, for teh overcharging matter to raise its ugly head. Until the spring thaw in McCall. So here I was, vacation, in McCall Id, in need of a new alternator (integral VR) and an intermittent, heat sensitive, CDI. Plus a leak in the inner rim of the 3 piece BBS on my own Porsche...that one to the left. Ordered the rim for BBS, the alternator from Pelican, sent the CDI off to Loren, none of my technical "resources", tools, available to me in Id. |
PRICELESS!!! |
This seems fairly cut and dry to me. |
| All times are GMT -8. The time now is 11:51 AM. |
