-   -   how do you know if you have an ignition control unit problem ? (http://forums.pelicanparts.com/porsche-911-technical-forum/676711-how-do-you-know-if-you-have-ignition-control-unit-problem.html)
Luc Bernier 05-08-2012 05:55 PM
what are the signs ?
thanks
Luc Bernier 05-09-2012 05:54 AM
to be more precise : how can I tell between problems from the fuel accumulator vs ignition control unit ?
ossiblue 05-09-2012 07:11 AM
First thing is to check for spark. If you have a consistent, strong spark, your problem is fuel related.
5String43 05-09-2012 07:22 AM
When the Permatune in my car started to go away, the car got much harder to start from cold.
boyt911sc 05-09-2012 08:15 AM
Fuel accumulator test.........
Luc,
You've been given simple test to determine if the FA is leaking or not in your other post. Test it and confirm it is not the culprit for your low residual fuel pressure (??). Troubleshooting is a process of elimination. Once the FA is tested and confirmed good, focus your search to other possible culprit/s. Have you checked your residual fuel pressure?
What do you mean by 'ignition control unit'? Be more specific and keep us posted.
Tony
T77911S 05-10-2012 06:27 AM
thanks
you have no spark and the car will not run.
if tony has given you advise about this in another thread, do what he says.
Tippy 05-10-2012 06:43 AM
I believe this was explained in the "MSD exposed" thread on why this happens.
