wannabee wannabee
Particular Yellow Spray Paint for H4 Lens
I'm looking for the shade of yellow on the right. Anyone know what it's called and where I can get one? Thank you.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) |
It's been a while but pretty sure I used Duplicolor Metalcast paint in yellow to do mine.
1975 Carrera Coupe #391 1980 924 11k orig miles 1974 914 2.0 LE Creamsicle 1979 Dodge Lil Red Express 2015 Wrangler Unlimited, and a bunch of bicycles. |
Flat Six
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
wannabee wannabee
Thanks but both appear to be brighter shades of yellow on the left of my posted pics. I'm looking for the pale one on the right. I think I found one but pricey at $41 shipped.
Vans Spray Lens Paint (Yellow, 130ml)|Automotive Lens' Painter|JDM Color Tailights Paints Anyone have leftovers they don't need?
I'm not convinced that the orange car just has Yellow Bulbs and clear lenses... the yellow bulb even when not in use will give the reflective cone part a yellow tint.
Yellow bulb option
Formerly known as Syzygy
Kevin 1987 ROW coupe, Marine blue, with a couple extra goodies. The cars we love the best are the ones with human traits, warts and all. |
I've used the Krylon Stained Glass Paint for clear turn signal lenses. It takes up to 8 coats to get to amber. By experimenting with the number of coats, chances are you can get to the right shade.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
wannabee wannabee
Folks, sorry if I have a confusing question. I'm trying to duplicate the lens color on the right below (dull) versus the brighter yellow on the left. Anyway I found a Vans Spray can for $30 on eBay an hour ago which would hopefully do the job. Thanks for the feedbacks.
99 C4 - (let's try this once more) 07 Cayman S - sold 11/17 (not the same) 84 Carrera - sold 3/16 (geez what have I done!) Last edited by WIL84911; 05-09-2012 at 01:24 PM.. |
RETIRED
The Krylon stained glass spray works great.....don't buy ANYTHING from Sierra Madre.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
what Bob said also ...
and you can buy yellow lenses ... then keep your stock ones so when you get pulled over and given a ticket you can put the legal ones back in ... if you get a real winner of an officer they can also point out and verify if your H4 lenses are not DOT approved .. most of them are not I believe ... true it would be an #@@ of an officer to do that but the yellow tint on them any place in the US I am 95% sure not legal in any state ... but its up to you .... |
I've used the Krylon Stained Glass paint and it turns out much paler than the bright plastic lenses you've shown on the left. The yellow bulb approach is also an option I've done, but the result is actually very subtle. The yellow really only shows when you look at the lights head on.
Krylon is the way to go unless you want to use actual yellow glass H1 lenses which will cost big $$$.
1973 Coupe Projekt X (AKA bunch o' boxes full of parts) |
Yellow Headlights are LEGAL in the California. Here's the link to the California Vehicle Code in regards to the colors of lamps: V C Section 25950 Color of Lamps and Reflectors
Years ago I had a car with yellow headlights and I printed out this section of the CVC and kept a laminated copy in the glove box. Ciao, n. |
