Guest
Posts: n/a
Started my 1974 911 today after sitting for several months while away. Car started fine but I noticed oil leaking from passenger side of exhaust and white smoke. That cleared up after running for about twenty minutes. Never a problem when driving often. No idea what to look at first...
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
White smoke usually means coolant or brake fluid. Since you are air cooled that's not an issue. Are you sure it's not blue smoke? (oil leak?) Water in the fuel will create steam from combustion chamber. If it's oil then you valve guide seals are leaking oil into the combustion chamber and burning it off in 20 minutes
- Kerry |
Undocumented User
I thought white smoke usually meant a new Pope.
Typically a 911 that sits for a period will smoke like crazy for awhile and all the seals etc that have dried out come back after getting lubrication for the first time you drive it after sitting..YMMV
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
Water is a byproduct of engine combustion. White smoke is the water vapor from the engine escaping into the air by the tail pipes. Clearing of white smoke after 20 minutes of idling is a bit long but quite possibly normal. This is also a reason why driving the car for 10 minutes everyday is extremely bad for the car because the engine is never hot enough to burn off all water in the oil and ruining the oil's capability as a lubricant.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
83 911 Production Cab #10
+1... Was going to post that until I saw yours
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
How long should it typically take for oil that's acumulated, say overnight, to burn off? 10+ mins?
1986 Meteor Grey Carrera - We'll meet again in Valhalla. |
Taking it apart is easy
Smoke after just sitting over night is not good. Many 911s will smoke after being parked for some weeks, but not over night.
Jerome PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com |
My car doesn't smoke, is that okay? Or should I take it back to Tom Williams?
Janna James 2013 Porsche 911 convertible, red, automatic/primary and 2012 BMW 750li sedan, gray, automatic/secondary Husband's 1962 Jaguar XKE, 1971 Ferrari Daytona Spyder, 1964 Porsche 356C, 2013 Porsche Cayenne Turbo |
