1986 911/Targa
Can't shut my door! Help
I was trying to fix the window switch, and I got curious with the door latch. I turned it, now I can't turn it back. Used the key to unlock it won't even budge. What to do. By the way. I fixed the window. It now goes up and down. Thanks guys.
Also, there is a place to,put the key right on the side of the door, what is that use for?
Old 05-09-2012, 02:30 PM
Oh Haha's Avatar
Is the door open or closed? If you can, try opening it with the INSIDE door handle.
The "other" key is typically for an alarm. If you have never used it, it's probably defunct.
Pacific Blue
Wayne
Old 05-09-2012, 02:49 PM
Fleabit peanut monkey
Bob Kontak's Avatar
I just twisted mine to replicate. It locked. I squeezed the outside door handle lever and it released.
Old 05-09-2012, 04:44 PM
Carrera3.2LG50's Avatar
I did the exact same thing once. First I freaked out. Then I tried the handles and one of them released it - can't recall if it was the inside or outside handle, but all was well after that. Decided not to do that again...
Old 05-09-2012, 07:10 PM
muck-raker
kidrock's Avatar
squeeze the handle and manipulate the door latch back to its original position.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-09-2012, 10:00 PM
1986 911/Targa
I did it. this one was not easy for me. I did what Mr. Bob contact suggested. Thanks guys.
Old 05-09-2012, 11:50 PM
Enthusiast
jrolstin's Avatar
I did this the other day and almost freaked out until I realized the outside handle releases it - scary moment.
Jonathon
1982 911 SC
www.avrmotorsports.com
Old 05-09-2012, 11:58 PM
na2ub's Avatar
You might be due to lube up your door mechanisms. Just sayin.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 05-10-2012, 05:24 AM
Bob Kontak's Avatar
We have all been through it. Nice feeling when it pops back open, eh?
kidrock has the real answer if there was a problem - lube or spring issue. Coax it back into place while pulling the handle then get your fixin' on.
Old 05-10-2012, 06:27 AM
Member 911 Anonymous
DRACO A5OG's Avatar
+1 what Bob wrote, I do this all he time to make sure all is working well with both doors.
No worries.
'85 Carrera Targa
PCA/POC
Old 05-10-2012, 10:02 AM
