chrisp's Avatar
Broken inside door handle/lever.
It seems like it would be easy to replace but I haven't taken it apart yet.
Is this a pretty straight forward job or are there parts other than the lever that I will need? i.e. are the pin and clip throw away parts or reuseable?
Should I replace with plastic or I am just waiting for them to break again and I should just do aluminum now? My door opening cables are very tight (that's why it broke). Is this typical?
Old 05-06-2002, 12:39 PM
Moses's Avatar
Lube the cables and lock. Definitely get an aluminum handle. Save the small circlips and pin, you need them for the new handle.
Old 05-06-2002, 02:02 PM
I redid mine last summer. I would suggest replacing all the little plastic pivots. I think there's 4 or 5 in each door. That's usually what makes the handle stiff and hard to pull. It onlt takes one bad one and it won't open any easier. They're only a couple bucks for all them and they're easy to replace while you have the door panel off.
Old 05-07-2002, 01:01 PM
