NeedSpace's Avatar
Bosch Fuel pump fittings needed
I have a setup very close to this picture below. I have the new check valve but I need the washers, the banjo fitting to my fuel line and the bosch cap nut. Could anyone point to where I can get this? Feel free to send a PM.
Old 05-12-2012, 11:55 AM
ROW '78 911 Targa
timmy2's Avatar
Try a WTB ad in the classifieds?
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-12-2012, 01:01 PM
Scott R's Avatar
Cap nut is a standard sized lug nut, works like a champ.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-12-2012, 02:35 PM
NeedSpace's Avatar
Good idea timmy...
WTB: Fuel line parts, right lens, tranny lug, wheel caps
Old 05-12-2012, 03:48 PM
You can buy the cap nut and washers for a few bucks from our host or the Porsche dealers.
Just order the cap nut and washers for the right diameter, 10 or 12mm.
Why would you buy used parts that may not seal properly anymore ?
cap nut, 12mm : 928-110-475-04
washers, 12mm : 900-123-005-20
cap nut, 10mm : 900-070-010-02
washers, 10mm : 900-123-144-30
Why would you change the banjo fitting on the fuel line ?
If you have a 76, your fuel line has a 10mm banjo. Is your check valve 12mm ?
I'm not sure, but from the PET there may be a 12 (fuel pump) to 10mm (fuel line) check valve, this would be 911-608-211-00.
-Guillaume
Old 05-13-2012, 06:19 AM
BoxsterGT's Avatar
Porsche Crest
I can help you with the banjo fitting & any fuel or oil hose you may need..............
Len at Autosportengineering dot com
Old 05-13-2012, 09:18 AM
I have the banjo and nut
Lorne M.
83 SC
Old 05-13-2012, 10:22 AM
