Carrera Script Decal Install Location
I'm about to install the Carrera script decal on the sides of the car.
Is there a consensus of how far up the sides to put it? For example, 2" above bottom of door? From which point should I be using to measure the vertical height, and what is that heigh number? Thanks!!
1986 911 Targa We affirm that the world’s magnificence has been enriched by a new beauty: the beauty of speed. A racing car whose hood is adorned with great pipes, like serpents of explosive breath - a roaring car that seems to ride on grapeshot.... |
I also have the same question...
Bill Kent https://www.facebook.com/#!/NoSweatPhotography 1987 Carrera Targa ![]() 1969 912 SWT #0053 |
I start mine exactly 1 3/4" from the bottom of the door- then be very meticulous about levelling the decal- I install mine DRY- I find installing them wet helps with bubbles on the flat parts but makes it impossible to wrap the fenders...
Hope that helped.
50mm from lower edge of door.
Left side ¨C¨ starts 10mm from front edge of door Right side last ¨a¨ finishes just before the front edge of door. |
RETIRED
Pics and install suggestions are on my website.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
How close??
Yes...very much. Thanks!!
About 5mm.
Follow Joe Bob instructions |
I didn't see in his instructions any measurements. Just "put it where you think it should go".
LOL....I have no idea where they should go.....
I meant the instructions on how to install the decal. Yes, he does not give any measurements.
But I gave you the measurements. You can see the pictures of the white and red Porsches that full_garage posted and figure out the measurements I gave you. |
see here on my website
excuses me i'm french so the explain are in french but you can see measurements in mm http://www.2l7registry.com/doc/decalc.pdf
www.2l7registry.com the Ultimate register website for all 911 2.7 for 74 to 77 |
There is an official Porsche factory document with the correct dimensions for proper application.I have this somewhere from the 80's when I restored RS 1126 and 2 others.back in the late 80's.I will look for it but it may still be available from Porsche perhaps some one knows a parts person who will search for it.It was a semi-gloss printed spec sheet not a photo copy.
Oh nevermind it can be viewed on the previous post submitted by tof2.7.
Where can you purchase the script??
PhD on Pending Projects
From Joe Bob... I have been buying mine for a few years... satisfied customer.
Drive safe! 1967 - Porsche 912 1981 - Porsche 911 SC 1991 - Porsche 911 C4 Wide-body Cabriolet |
RETIRED
Yupperz.....I gotz em.
Joe Bob,
I've been looking for the Carrera Script for quite a while now and did indeed find one, but was not able to install that script (is a damaged file). Is there a possibility for me getting your version of the Carrera Script? Pascal Last edited by pas@l; 07-19-2016 at 04:40 AM.. |
RETIRED
If you are asking me to provide to you my vector file for the side script, sorry that is proprietary. Took me a long time to get it right. I would be happy to sell it to you. or the finished product. but the file would cost more than the finished product.....
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel Last edited by Joe Bob; 07-19-2016 at 10:34 AM.. |
Jeff Jensen 1973 911 |
old post
