pokeytom's Avatar
Wont idle
Hi Guys: 1977 911s starts fine and idles good. warms up won't idle????? Whats going on?
Help, thanks
Old 05-15-2012, 02:05 PM
76 911S Targa
Hey Pokey! Shoot a pic of the engine compartment which will help establish the bonafides of your ignition and fuel system. Then the gurus can get to work helping you. Do you have standard ignition system? What have you done so far? Do you have the standard CIS for a 77 911S or a modified fuel system? They will ask if you have checked fuel pressures. When did the problems start? We await your reply.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 05-15-2012, 02:23 PM
