Who has a single crank pulley on their 3.6 and have you had any problems as a result?
I'm debating whether or not to remove my patrick motorsports single crank pulley and going back to the stock dual pulley with harmonic balancer on a 1989 3.6 rebuild that is just getting completed. Thanks for any experienced responses.
1980 911SC Targa 3.6L
Old 05-13-2012, 09:39 AM
Bill Verburg's Avatar
I've got one on one of my engines, It's a bastard setup, 964 bottom end w/ 993 top end and Motronic. No problems her in 5 yrs of use.
I couple of track acquaintenses run a single non harmonic balancer pulleys of their 964 Cup cars, again no issues.
Bill Verburg
Old 05-13-2012, 02:42 PM
Bill, do you still recommend using a harmonic balancer or has your opinion changed due to lack of confirmed failures? Thanks, Jim
Originally Posted by mjshira
so I have a 964 engine with a Clewett pulley system on it, it is bigger than the RSR lower pulley but not as heavy as the stock harmonic bal. Issue?
The thing about the 964 crank is that it is not as torsionally stiff as a 993 crank or the earlier 911/930 cranks. Each time a cylinder fires it twists the crank a little bit. All the little bits of twist can resonate w/ each other at a given crank speed(what the resonance rpm is I haven't a clue), think Tacoma narrows bridge though. A harmonic balancer as used on the 964 has a weighted outer ring separated form the inner ring by an elastic medium. The elastic medium absorbs and dissipates the extra twist energy.
Now some do run w/o the harmonic balancer, I have seen several M001 964 Cups w/o one, but personally I wouldn't.
The M001 993 Cups that used the 964 cranks fro theiir increased bearing area also used the h/b in all cases
Bill Verburg
2011 Cayman Speed Yellow
1988 924S (Sold) 2000 Boxster S (Sold)
2006 Cayman S (Sold) 1990 964 C2 (Sold)
1978 911 SC (Sold)
Old 05-13-2012, 03:26 PM
Grand Am/IMSA Data Guy
Porsche84's Avatar
I have a single pulley on my 964 and it has been fine, 7 or 8 years. I have done about 5 other 3.6 conversions, all with single pulley. Not to worry.
Jerry Austin
AIM Data Products Dealer
84 911 3.6 track car - Sold
Morris Minor Van with S2000 running gear
http://austinmotorsportsllc.com/
Old 05-13-2012, 03:28 PM
Jerry do you do any work on the cranks before conversions? Rebalance ? Otherwise stock engines? You are talking crank pulley correct? Just confirming thanks.
Old 05-13-2012, 06:26 PM
Porsche84's Avatar
I just replace the stock crank pulley with Patrick's single pulley. All of the cars are DE cars so they get a lot of high revs. No issues on any engine. I'm sureJim Patrick has done many himself. One of the cars I did was a 3.6 into a 914 (what Patrick specializes in). No choice there but to use a single pulley, no room for a double.
Jerry Austin
Old 05-14-2012, 03:52 AM
Tom '74 911's Avatar
I've been running a single pulley conversion on my 3.6L, but only for a little over a year - so I can't offer much in the way of long term durability testing etc....
I have a Patrick lower pulley and a Rothsport upper hub. . . I did the conversion so I could use a 3.2L engine mount and cross bar.
Tom
'74 911 Red Sunroof Coupe, 3.6L, etc...
'76 912 Yellow SPEC 911/911CUP
Old 05-14-2012, 06:41 AM
Bump to front. Looking for more experienced single pulley crank 3.6 applications.
Old 05-14-2012, 09:45 AM
skinnerd's Avatar
I got a single on my Vram.
Rothsport (Oregon) built the engine.
No problems at all.
They have done many of these 3.6 conversions, most with the single pulley I'm sure.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 05-14-2012, 10:31 AM
RETIRED
Joe Bob's Avatar
Been five -six years. Except that it has to get rev to turn the alt light out, no problems.
2012 ML350 3.0 Turbo Diesel
Old 05-14-2012, 10:55 AM
Brown Out
RRWood's Avatar
Patrick Single Pulley
I second Joe Bob's comment.
RR Wood
1960 Corvette
1980 911SC 3.6
1998 Chevrolet S10 Sportside LS1
Old 05-14-2012, 01:37 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Yep, I've ran them as well with no issues.
Old 05-14-2012, 02:02 PM
not one failure attributed to removing the harmonic balancer?
Old 05-15-2012, 06:14 AM
Bumpity bump
Old 05-16-2012, 02:41 PM
