jdill
85 start issue
hey guys i have an 85 that is having a problem,if you turn the key it will crank but not start,,, so while checking the power at the fuse box to the fuel pump i noticed with a slight tap of the key it starts,,, so i changed the ignition switch figuring that was the culprit but it is doing the same thing,, any suggestions thanx in advance
79 928 euro -lint green/black leather 5 speed
Old 05-16-2012, 06:27 AM
CDN Redneck
Capt J.D.'s Avatar
Most probably either the reference sender or speed sensor.
84 Carrera Coupe 3.2L Tea Tray Tail Black on Black
Old 05-16-2012, 06:40 AM
Monkey+Football
Icemaster's Avatar
Send a message via AIM to Icemaster
With a slight tap of the key, the engine starts or the fuel pump starts? Or did changing the ignition switch stop the slight tap issue?
My first stop is always the DME relay. Under the front seat.
<Insert witty comment>
85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff.
Old 05-16-2012, 07:05 AM
jdill
with a slight tap of the key the engine starts ,
Old 05-16-2012, 07:17 AM
jdill
and when i changed the ignition switch the problem remained the same
Old 05-16-2012, 07:26 AM
Monkey+Football
Icemaster's Avatar
If it starts, it's not the DME.
Old 05-16-2012, 07:42 AM
Flat Six
Flat Six's Avatar
Based on what you've described I'd bet it's the FP relay. Could be intermittent DME relay (I guess maybe they're all intermittent?) so I'd try R&R of that first. But also R&R FP relay -- loose/dirty connection or intermittent/failing relay. Cheap replacement.
Hope this helps.
Dale
Dale
1985 Carrera 3.2 -- SOLD
2026 Jaguar F-Pace / 2025 Ford Bronco Sport
Old 05-16-2012, 08:28 AM
muck-raker
kidrock's Avatar
turning the fuses and changing the relays are easy and quick. But you really need to isolate the issue and find out whether you are lacking fuel or spark. Next time the car refuses to start, do a fuel and spark check.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 05-16-2012, 10:35 AM
