-   -   Flapper box cables question (http://forums.pelicanparts.com/porsche-911-technical-forum/678242-flapper-box-cables-question.html)
supersquid 05-16-2012 10:27 AM
About done with my engine rebuild and want to restore my flapper boxes because they seem easy to get to right now.Anyway I got them loose but the cable ends are badly fused to the boxes,checked our host for replacements and seems there are no twin cable system replacement cables.If that is true can I switch to a single cable system?
Or am I completely delusional and all the early flapper cable systems are the same?
Thanks,
Sam
1969 911T NYC
Bob Kontak 05-16-2012 11:06 AM
I think this is the one you need.
Pelican Parts - Product Information: 901-424-701-05-M100
Check pdf page 315 (below) to get the diagram and part numbers. Then load part number into Pelican's search engine
http://www.porsche.com/all/media/pdf/originalparts/usa/911-1_USA_KATALOG.pdf
mcaterino 05-16-2012 12:03 PM
Sam,
You should find that it's just a single cable bent through an eye in the lever, then going back through tubes in the tunnel to each box. It'll be a bit of a pain to feed through, but pulling up the whole emergency brake console it should be doable.
Mike
javadog 05-16-2012 01:10 PM
There are a couple different cables. If you have one lever, you need the single cable that is bent in half (in a loop, really) in the middle, so one end goes through each tube.
JR
