i took the car up to the shop, which bothered me the most, since i always like to do my own work and i didnt want to let it get the best of me, but anyway...
the owner assured me the rack was perfectly fine and super tight when he checked it. He reached under the front trunk lid, adjusted the steering coupler a couple times...and FIXED...no more clunk. At least for now anyway.
now i need a new steering cover thingy...my stock paper one is toast.
Old 05-21-2012, 07:46 AM
na2ub's Avatar
Nice.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 05-21-2012, 08:45 AM
86FlatSix
JQ911's Avatar
reviving thread - clunking when steering
At a stop, I hear clunking when I turn the steering and sometime hear a thug when I hit a bump. I started to hear this when I was turning the next street and hit a pothole and by the way, my car was lowered a little below euro height a few days after I hit the pothole.
Based on the discussions on similar symptoms, I need to check the following:
1. Bolt on the center rack
2. Add bump steer and reposition the steering rack
3. Lubricate bearings
Otherwise, I damaged the rack.
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 05-22-2013, 07:49 PM
dshepp806's Avatar
My "pop", from long ago--when turning the steering wheel --was certainly the steering rack..changeout resolved immediately.
Best,
Doyle
Recording Engineer, Administrator and Entrepeneur
Designer of Fine Studios, Tube Amplifier Guru
1989 Porsche 911 Carrera Coupe
25th Anniversary Special Edition
Middle Georgia
Old 05-22-2013, 08:23 PM
86FlatSix
JQ911's Avatar
Best,
Doyle
That is what it looks like. A damaged one that needs to be replaced. Nonetheless, will check it out tomorrow morning and might be in the look out for a steering rack. Thanks!
Old 05-22-2013, 08:51 PM
nineball, your CF steering shaft cover is ready
Old 05-23-2013, 04:06 AM
86FlatSix
JQ911's Avatar
Just an update, we lifted the car earlier and tried to find out the source of the clunk or thug when I am moving slowly. We tried to wiggle the steering rack while my friend was turning the steering wheel no clunking/thug sound. However, when we wiggled the Fuchs in an upward/downward motion, there is a clucking sound. Looks like my left lower ball joint and outer tie rod looks toasted.
Will check the ball joints first and see if the clunking sound disappears.
Old 05-23-2013, 07:02 AM
nineball's Avatar
thanks java
fs thread:
Carbon Fiber and Fiberglass steering shaft covers available
- He gave his father "the talk"
- Once while sailing around the world he found a shortcut
- He taught a german shepard how to bark in spanish
He is.... nineball. I don't always drive sports cars, but when I do I drive a 1983 911SC Targa. Stay fast my friends.
Old 05-23-2013, 09:32 AM
86FlatSix
JQ911's Avatar
Follow up questions, since I am changing ball joints and tie-rods, would you recommend I get the Turbo Tie-rods?
Old 05-24-2013, 11:40 AM
nineball's Avatar
yes
Old 05-24-2013, 11:55 AM
86FlatSix
JQ911's Avatar
Originally Posted by nineball View Post
yes
Thanks!
86FlatSix
JQ911's Avatar
The clunking sound was traced to the sway bars, problem solved. While at it, replaced both ball joints (wiggling left wheel) and as recommended installed turbo tie-rods, aligned/cambered. Worth the spirited drive back home with all the new parts.
PS - We installed a bump steer kit to complement the lowered height.
Old 06-04-2013, 03:08 PM
Send a message via AIM to morrisjm1 Send a message via Yahoo to morrisjm1
After I completely rebuilt my suspension, with ER poly bronze bushes front and rear, new TB, ASP, new inserts and shocks in the back, ball joints, rebuilt steering, mono ball strut mounts and control arms, turbo tie rods, I still had a clunk. The only thing that wasn't new were the bushes in the struts where the inserts ride. Sure enough, there was play.
I sent them to Craig Garrett, garrett@iserv.net, (616) 862-5466. I found his name searching this forum. He did a great job, quick turnaround, fair price.
It might be your problem.
Mike
'78 911SC Targa (SCWDP member #17)
'74 MGB (one owner)
Pickup
2013 Ford Explorer Sport
2013 VW Golf TDI
Old 06-04-2013, 05:49 PM
