just brought my new 911 to CA and failed smog :(
No biggie, all the emissions stuff checked out fine. But Mr. Dennis Wong says my airbox has been tampered with. It looks OK to me.
1986 3.2 Meteor Metallic Grey |
looks like the top has been cut off, to me.
Airbox
Dennis tells no lies, the top has been cut off your airbox. I have a spare if you want it. PM me
They failed your car for that?????!!!???
Yep. Gotta love California.
the seller didnt smog it for you? maybe you got it from another state...but if it is a cali purchase, the seller is obligated to get it to pass first.
poof! gone |
You need to find a new smog guy... Clearly while modified that would not impact emissions. Alas, this is the reason I have had '74 and older cars.
Less brakes, more gas!
LOL This is the WHOLE reason I refuse to EVER move or live in CA...
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Tired Member
Glenn Daily Driver - '78 911SC RoW Endurance Racer - '85.1 944 Street/Track Project - '86 951 Race Project - 944 Spec |
Mr Dennis Wong is not following his own guide lines. You are saying the numbers were all good but he failed you because of the modification? What a dick, pun intended Mr Wong.
There is a Visual and a Tailpipe test, the OP obviously failed the Visual.
-Mat 78 911SC |
Buy yourself a K&N filter and get rid of that big old box thing.
I bought a spare, stock air-box cover just for this purpose. It was around $30 used.
Al |
AutoBahned
+1 - in the chain of restrictions I don't think the filter cover comes close to significant. I don't recall reading that on any threads here. The pick up point using the stock part might grab cooler air, just a thought. In any case the cut up cover looks.... bad in IMHO.
Sold: 1989 3.2 coupe, 112k miles |
k&n's are junk IMO. I won't ever use one. Paper filters the air better, is cheaper to buy, and is easier to maintain.
SOLD: '87 Carrera |
AutoBahned
I don't know if I'd say junk, but I would never use a K&N on a road car if I could use a paper filter.
People have posted links to tests here re K&N; also as hcoles noted there is nothing about the cover restricting air flow; instead, old posts of tests on here show just the opposite, and I think Bruce Anderson found the same thing. |
The following emissions components are also part of the visual portion of the smog inspection. The smog technician will need to see that they are present and properly connected. Most modern vehicles are equipped with most of these components.
- Air Filter & Housing - Throttle Position Sensor (TPS) - Engine Coolant Temp Sensor (ECT) - Manifold Absolute Pressure (MAP) - Crankshaft Position Sensor (CKP) - Camshaft Position Sensor (CPS) - Intake Air Temperature Sensor (IAT) I guess Mr Wong was just doing his job, sorry Mr Wong. |
Burnin' Rubber
Failing visuals because of that is absolutely ridiculous. The least they coulda done is to tell you that the cut cover won't pass, technically, and that you outta have a proper box cover. But failing you for that is a total joke. Cali CARB is a freakin' joke!
