Aero geeks need input
at speed on a 911/912, with no tail, is air going IN to the engine compartment through the grill or is air being pulled out of the engine compartment?
I ask be cause I need to determine whether to have the fans on the grill mounted oil cooler push or pull. Thoughts theorys? Brgds, Peter
Brgds, Peter Baldauf 1967 912 1988 911 vert 944 TS 1969 911 E 1956 356 Conti 1983 911 SC |
Senior Advisor
although that is a negative to zero area, the fan and the intake pull air in. the fan exhausts to the bottom.
08 Cayenne Turbo |
So I'll keep them pulling air in.....
