Best way to check if the timing Z1 mark is off?
I think my timing mark is off, a previous owner had replaced the chain tensioners and it runs bad if not significantly advanced at idle. What could I do to see if the timing position is correct? 79 SC
Well the timing mark/pulley is keyed to the crankshaft, you would need to check the cam timing individually.
Could I tell enough from having the valve cover off or am I talking about taking the motor out? If the cam was shimmed how could I tell?
Thanks in advance! |
Pelican Technical Article: Setting and Adjusting the Cam Timing - 911 (1965-89) - 930 Turbo (1975-89)
Wayne's rebuilding book helps a lot too. |
Thanks! Brian |
| All times are GMT -8. The time now is 08:23 PM. |
