Best way to check if the timing Z1 mark is off?
I think my timing mark is off, a previous owner had replaced the chain tensioners and it runs bad if not significantly advanced at idle. What could I do to see if the timing position is correct? 79 SC
Old 05-18-2012, 06:42 PM
Scott R's Avatar
Well the timing mark/pulley is keyed to the crankshaft, you would need to check the cam timing individually.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-18-2012, 06:53 PM
Could I tell enough from having the valve cover off or am I talking about taking the motor out? If the cam was shimmed how could I tell?
Thanks in advance!
Old 05-18-2012, 07:03 PM
ROW '78 911 Targa
timmy2's Avatar
Pelican Technical Article: Setting and Adjusting the Cam Timing - 911 (1965-89) - 930 Turbo (1975-89)
Wayne's rebuilding book helps a lot too.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-18-2012, 07:39 PM
Originally Posted by timmy2 View Post
This is exactly what I'm looking for. I'll look for the valve lift overlap "intersection" on both cams and see if it aligns with Z1.
Thanks!
Brian
Old 05-18-2012, 08:20 PM
