help with remove complete air con
hi guys , i want to remove complete air con from my 80 sc lhd . i cant not find any photos to show me how ?or any photos can show which parts i have to remove it . and is this job can be done in garage or i have to send out to evc some gas first ( i heard from someway ) ? sorry i m noobs
Old 05-03-2012, 01:52 AM
geoz's Avatar
You can do this yourself with standard tools in your garage. Have the system evaced efore you start. Locate key components (cond under deck lid, in the front, compressor, evap in smugglers box, dryer in left front wheel arch).
Follow the hoses. If you don't want to replace the system cut the hoses and save yourself a lot of trouble.
Old 05-03-2012, 02:21 AM
thanx geoz for reply , so there is no any dangers gas in the systerm right ?
Old 05-03-2012, 02:30 AM
VFR750's Avatar
Yes there is freon in your system. It needs to be evacuated by a pro. A typical service center, like Midas can do it. Cost me small dollars back in 2005-6. Like $50 or so.
Old 05-03-2012, 02:49 AM
geoz's Avatar
as I said have the system evacuated - by a pro shop - before you start.
the rest is straight forward.
cheers
hg
1988 911 Cabrio
Old 05-03-2012, 03:41 AM
ok cool thanx guys
Old 05-03-2012, 04:22 AM
Fleabit peanut monkey
Bob Kontak's Avatar
The refrigerant is harmful to the environment. It is not explosive or flammable (under routine conditions) but is not allowed to be released in the atmosphere in the US. From what I have read on Google in the last three minutes, the handling laws in Australia are more strict than the US.
Refrigerant Handling Licence Frequently Asked Questions - Australian Refrigeration Council Ltd
Old 05-03-2012, 05:17 AM
Northern Motorhead
wildcat077's Avatar
Chances are kj's system is already empty anyways,as they were all known to leak !
I removed my AC system down to the last bolt two years ago and it sure gives you much more access in the engine bay.
Be patient and everything will come off smoothly ... some things with a little more effort but it all comes out
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 05-03-2012, 06:27 AM
Model Citizen
herr_oberst's Avatar
Cheers !
Phil
It does indeed. If you really want to be anal, re-use the screws and rubber washers (with a dab of silicone) to plug the holes where the hoses route. In this spirit, you may want to cover some large holes in the smugglers box and you'll need to shape a piece of tin for where the compressor bracket used to be in the engine bay, but you can easily do the whole job start to end in a weekend, or even a long Saturday.
Old 05-03-2012, 06:59 AM
anyone have the picture about air con and which parts i can remove it thanx i just want make sure which part i can remove it .
Old 05-04-2012, 11:47 PM
tazzieman's Avatar
No pic ; just start in engine bay , disconnect hoses from compressor - remove compressor and its brackets. Remove radiator thingy from under engine lid. Remove blower and associated thingy from inside smuggler's box. Remove blower next to battery (black cone thingy to right of the jack). Then have some fun pulling out all the hoses. I had to saw through some of mine , nasty job with the wire reinforced hosing.
Plug all holes and go for a spin in your even more agile 911
Weigh all the junk you removed and give yourself a pat on the back.
You now have:
1. better acceleration
2. better fuel economy
3. more effective brakes
4. less weight hanging behind the back axle , useful when on the limit!
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 05-05-2012, 02:44 AM
thanx tazzieman
Old 05-05-2012, 06:47 AM
hi guys , just want to check am i on the right track . here is two photos that i took today and the red arrow is show that what i m goin to disconnect it . see if is right . let me know pls . thanx
Old 05-18-2012, 11:11 PM
tazzieman's Avatar
Yep , pull it all out!
As long as fuel doesn't drip out you are on the right track
It's a very cathartic process and you should enjoy every bolt removed.
Old 05-19-2012, 01:33 AM
thank you ,
Old 05-19-2012, 01:42 AM
Scott R's Avatar
You have a pretty interesting updated AC system there, I wonder what other interesting pieces you may have at the end of those hoses. Certainly not factory for an SC.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-19-2012, 09:23 AM
That sure doesn't look like the system in my '84 or an SC that I can remember. I'm currently having an internal debate about removing my ac.
Dean
Old 05-19-2012, 09:33 AM
really ? so this is aftermaket air con ?
and also i got question on that bolt ( see the yellow arrow )
is this bolt i can remove , it seen like the bolt is hold the engine mount bar , is that safe to remove the bolt . thanx guys , sorry i m noobs
Old 05-19-2012, 05:23 PM
here is the photos
Old 05-19-2012, 05:25 PM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
why are you removing this? it looks like an updated aftermarket system. have you tried having it re-charged to see if it works?
SOLD: '87 Carrera
Old 05-19-2012, 05:40 PM
