Buck Nasty
xxultramistersi's Avatar
1989 Carrera "dieseling" Problem
Just checking to see if anyone has seen this problem.
I have a 1989 carrera 3.2 that has had moderate engine work done to it, but nothing too serious. Recently, the car has been "dieseling" upon shut off. After I turn the ignition off, the car seems to try and start itself up again. There is no power but the engine keeps sputtering and attempting to turn itself over. It usually does this for a few seconds then shuts off. However, sometimes it keeps going, and since there is no more power to shut off I just stalled it to stop the engine from turning. Start up after these occurrences is also problematic, and it sometimes takes 2 tries to get the car running. Once it is running it runs great. Any thoughts?
Thanks,
Andrew
"I couldn't find the sports car of my dreams, so I built it myself"-Ferdinand Porsche
1989 Carrera 3.2 Coupe
1996 Carrera 4 Cabrio
Old 05-21-2012, 05:43 PM
db_cooper's Avatar
Try a new DME relay..the one under the driver's seat. You should have a spare DME relay as a spare.
Sounds like the fuel/ignition is staying "live" with the key off..that would be a DME relay problem.
To "diesel" with the ignition off (assuming a hot spot in the combustion chambers) the engine need fuel, which it should not get with the DME system off.
$30 from our host: 911-618-154-01-M252
Old 05-21-2012, 06:28 PM
If it is not an electrical issue, I would run through some Techron(or the equivalent). There could be some deposits that are burniong upon shutoff.
Also, do you run the car hard? If not, you should.
For all we know, your car will merely need an "Italian Tuneup".
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 05-22-2012, 07:04 AM
redstrosekNic's Avatar
Dieseling can be horrible for any engine. Make sure you slowly let the clutch out when you're in gear as you turn the car off.
Dustin
Old 05-22-2012, 08:15 AM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
... not a diesel engine.
SOLD: '87 Carrera
Old 05-22-2012, 08:43 AM
Lol you got me
Dustin
Old 05-22-2012, 08:53 AM
It's your car's way of saying it wants to be driven more ...
Old 05-22-2012, 09:17 AM
Chain fence eating turbo
I'd say you have leaking injectors.
1. With key off, no more fuel should be injected
2. Hard starting indicating fuel pressure bleed off.
Old 05-22-2012, 09:48 AM
even with leaking injectors (probable) it still needs ignition so you probably have carbon build up also, it is glowing.
PS- There is a chance when it is "dieseling" it is running backwards! Not good
Old 05-22-2012, 10:10 AM
Yes, carbon being ignition point. These motors develop a lot carbon due to their inherent design.
I agree, the chain tensioners only like to work in the correct direction. When you turn the engine backwards, it seems like the chain wants to jump the sprockets. Not saying it will, but it makes you feel uneasy when looking at it while turning.
Old 05-22-2012, 10:38 AM
Something is leaking fuel into the manifold, either an injector or the fuel pressure regulator or dampner.
You can remove the vacuum hose to the regulators and use a hand held vacuum pump to see if they hold vacuum (as they should). Leaking injectors you can possibly fix with some seafoam or techron and a 'not-safe-for-your-license' drive, but best to send them out to be cleaned.
Chuck.H
'89 TurboLookTarga, 334k miles
Old 05-22-2012, 10:47 AM
Damper is on right, FPR on left. Like Chuck said, if you smell a strong odor of fuel in either vacuum line, it is more than likely the culprit. You may smell a faint smell after all these years. Mine do.
Old 05-22-2012, 11:42 AM
