-   -   How to Fill A/C compressor stand hole (http://forums.pelicanparts.com/porsche-911-technical-forum/679437-how-fill-c-compressor-stand-hole.html)
Don Ivey 05-22-2012 04:06 PM
I've removed my A/C compressor and stand (what a bear!), and now have a a small rectangular hole where the stand went through the tin. Should thgis be filled, and if so, how could I do it. I'm thinking of the heater blower delete next, so maybe these could segue somehow. Any ideas? TIA,
Don Ivey 05-23-2012 05:41 AM
Bump. Any help?
Josh D 05-23-2012 08:39 AM
Maybe a picture would help? I can't think off the top of my head where the compressor bracket mounts below the tin.
timmy2 05-23-2012 09:06 AM
Small rectangular hole, cut a small piece of sheet metal, paint it and silicone it for now. When engine is out have it welded if you need to for cosmetics.
James Brown 05-23-2012 09:11 AM
it won't effect the cooling if that is your question. the small tin is the best bet.
gtc 05-23-2012 09:12 AM
Are you talking about the tin down near the crank pulley? I didn't worry about it.
Don Ivey 05-23-2012 02:39 PM
Actually, that was what I was concerned about. I should have asked it that way, as I'm ok with cutting a piece of tin and attaching it. Thanks,
Cooper911SC 05-24-2012 08:00 AM
I cut out a piece of sheetmetal to fit and drilled holes to utilize the adjacent M6 tapped hole in the chain cover and the nut on the sheetmetal. Sprayed it satin black to match. Just need two more of the bolts for the engine tin.
Cooper
