OsoMoore's Avatar
Find and Read your Owner's Manual!
I acquired (most of) the owner's manual for my 79 SC, and have been reading through it. There are a lot of things I didn't know, as well as some things that are generally awesome.
  • Gas tank is 21.13 gallons. I thought it was ~16.
  • Recommended gas is 87 Octane. I thought I needed 93.
  • Apply Glycerin or Talcum to rubber seals to keep it soft and avoid cracking
Awesome charts of HP, gear ratios, etc.
Go get a copy and read it!
Lillie - 1979 911 SC Targa, The Original 911 SCWDP Car. Currently in open heart surgery.
Old 05-23-2012, 11:28 AM
S2GART's Avatar
When Porsche switched to the 3.2 engine, they added electronic fuel injection and required Premium gas. I too was surprised when I bought my SC that I could get away with 87. That can come in handy money wise when you are filling up 21 gallons. Here in CT 93 octane cost $4.30 a gallon......you do the math
I too was impressed with the owner's manual. In all the cars I have owned, I have never seen a power graph and shift point graph.
The "collection"
1983 911 SC Targa (1 of 1430 imported)
1994 MB E320 Coupe (1 of 825 imported)
1992 MB 190E 2.6
2004 Volvo V70 2.5 Turbo (1 of a bazillion imported)
Old 05-24-2012, 05:06 AM
I've read that Premium gas is cheap insurance against engine knocking on older less than perfect running engines.
Also read that you may not feel or hear it knocking, but damage can be done just the same. If you hear or feel some knocking it's too late, the damage is done.
The most curious thing I found out when reading my owners manual, was the location of the intermittent windshield wiper control. Somehow, it was alway behind a blind-spot, and located on the dash just behind the steering wheel. Not where I would have expected it at all.
Old 05-24-2012, 05:40 AM
Best opening line in the history of owner's manuals:
Judging by the car you have chosen, you are a motorist of a special breed, and you are probably no novice when it comes to automobiles.
I always thought the sentence following that should have been:
Which is good, because our heating, ventilation and air conditioning systems are designed to confuse and befuddle the finest minds.
Brian
'82 SC Targa
'83 SC Cabriolet
Old 05-24-2012, 05:53 AM
OsoMoore's Avatar
That is disconcerting. Can anyone share some direct experience? I'm also going to hunt about with the search function.
Old 05-24-2012, 07:16 AM
Look at it this way:
Assume you drive 5000 miles/yr
Assume you average 20 mpg
Assume 30 cent difference regular to premium
Therefore 250 gal/year.
Savings of using regular over premium: $75
Cost of a new engine overhaul: Thousands ($10K??)
I am really cheap. But we are talking about $75-$200 a year depending on how many miles you drive. You probably spend $75 just purchasing the oil every time you do an oil change. I don't risk it, I use Premium.
Old 05-24-2012, 07:30 AM
Banned
Send a message via AIM to prebordao Send a message via Yahoo to prebordao Send a message via Skype™ to prebordao
I don't know if a modern 911 manual has the same detail. Can anyone chime in ?
Anyway, in the "old days" car manuals were a lot more technical. I remember seeing the manual for my father's early 60's Beetle and it had detailed cross drawings of the body, engine and gearbox ! How many would care about that now ?
Old 05-24-2012, 07:48 AM
OsoMoore's Avatar
I just reached the same conclusion. And I only pay ~$0.20 more per gallon, so I'm closer to $50 a year. That pretty much settles it for me.
Old 05-24-2012, 07:49 AM
Designer King
Paulporsche's Avatar
When you look @ octane requirements, make sure you are quoting RON, MON or PON (RON+MON/2) figures. PON (US & Canada) figures are about 4 or 5 lower than RON (European) but are equivalent.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-24-2012, 08:22 AM
Banned
Originally Posted by 1982911sctarga View Post
best opening line in the history of owner's manuals:
judging by the car you have chosen, you are a motorist of a special breed, and you are probably no novice when it comes to automobiles.
i always thought the sentence following that should have been:
which is good, because our heating, ventilation and air conditioning systems are designed to confuse and befuddle the finest minds.
brian
lol.
Old 05-24-2012, 08:46 AM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
$75 per year difference... that's $6.25 per month. You can't even buy one fast-food lunch for that.
"Saving money" by using 87 octane instead of 93 is fool's economy.
SOLD: '87 Carrera
Old 05-24-2012, 12:35 PM
Taking it apart is easy
Jerome74911S's Avatar
Well, there you go. I hadn't done the math, but now that I see it, the best premium gas, only.
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 05-24-2012, 02:28 PM
porwolf's Avatar
Since I got my 79SC in 1979 I have driven it for 50,000 miles with only regular gasoline. I was convinced that the low compression ratio of the 79 SC of only 8.5:1 does not require any higher octane rating. Also I never experienced knocking under any condition. Sure, higher octanes don't seem to hurt but I don't think they are necessary for a compression of 8.5:1. The reason for the low compression ratio, at the time, for the 79 SC was that it reduces dramatically the NO2 of the exhaust. Porsche at the time compensated the lower compression performance with the higher 3L displacement engine for the SC models.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 05-24-2012, 02:50 PM
I know the 993's have max speed in each gear published. My old neighbor had bought one and was shocked to see that in a manual.
Old 05-25-2012, 05:09 AM
