Blinker/Running Lights Issue of my '89
I was replacing a bad bulb in right front blinker of my 89 Targa. When I took bulb out the reflector assembly about fell apart so I ordered 2 units thinking the other side was in same shape. When they arrived I just needed the lens/reflector assembly so I disconnected the 3 wires and replaced the reflector(otherwise you need to remove the front bumper to replace blinker light assembly). Now I can't get the right side running light on and no right blinker, the light is on but does not blink- anyone know the correct way to connect the wires to the terminals of the reflector assembly? Left side is working, also when I use blinkers I get the rapid blinker instead of the slower speed.
Carl
Old 05-25-2012, 12:53 PM
