-   -   Quick Q: How do I remove Fuchs center caps? (http://forums.pelicanparts.com/porsche-911-technical-forum/680226-quick-q-how-do-i-remove-fuchs-center-caps.html)
markmalin 05-27-2012 07:10 AM
I'm about to start in on rear bearing job and need to loosen the axle nut with the wheels on the ground. I just want to know how to get the center caps off the Fuchs w/out damaging anything.
TIA!
Mark.
djcdmv 05-27-2012 07:38 AM
I'm sure the more experienced pelicans can give better advice, but I was able to get mine off by taking some stiff but pliable plastic coated wire and making a "C" shape with a 1 mm 90 degree bend on the end. Use it to grip the slight lip on the backside of the center cap at the 12 and 6 o'clock positions and pull gently. Got all mine off in about 1 minute.
dipso 05-27-2012 07:59 AM
Depends on the type of cap. Mine have set screws that can only be removed from the inside. Just pull off the wheel and either loosen the screws from the inside or pop em out from the inside.
Then you will probably have to put the wheel back on in order to lower it to the ground, to hold the drum tight when loosening the axle nut.
Joe Bob 05-27-2012 08:39 AM
A wooden dowel on the inside and a whack with a mallet. If they have two small holes a coat hanger cut to length in a U shape and a 90 degree turn on the end will work.
86 911 Targa 05-27-2012 10:09 AM
Wheel Caps.
Hope this helps:
http://forums.pelicanparts.com/uploa...1338138579.jpg
Gerry
markmalin 05-27-2012 05:15 PM
cool! I think I can rig something up. All else fails... I guess I can pull the wheels, then remove them and put them back on and lower the car to loosen the nut - but hopefully a little tool like this will allow me to pull them while the wheels are on the car :)
Originally Posted by 86 911 Targa (Post 6770589)
Charlie V 05-27-2012 09:55 PM
You might have these..........
Pelican Parts - Product Information: PEL-PP905952
