markmalin's Avatar
Quick Q: How do I remove Fuchs center caps?
I'm about to start in on rear bearing job and need to loosen the axle nut with the wheels on the ground. I just want to know how to get the center caps off the Fuchs w/out damaging anything.
TIA!
Mark.
Mark - New Glarus, WI
Old 05-27-2012, 07:10 AM
djcdmv's Avatar
I'm sure the more experienced pelicans can give better advice, but I was able to get mine off by taking some stiff but pliable plastic coated wire and making a "C" shape with a 1 mm 90 degree bend on the end. Use it to grip the slight lip on the backside of the center cap at the 12 and 6 o'clock positions and pull gently. Got all mine off in about 1 minute.
Dave
Black 1985 911 Carrera M491
Old 05-27-2012, 07:38 AM
Banned
Depends on the type of cap. Mine have set screws that can only be removed from the inside. Just pull off the wheel and either loosen the screws from the inside or pop em out from the inside.
Then you will probably have to put the wheel back on in order to lower it to the ground, to hold the drum tight when loosening the axle nut.
Old 05-27-2012, 07:59 AM
RETIRED
Joe Bob's Avatar
A wooden dowel on the inside and a whack with a mallet. If they have two small holes a coat hanger cut to length in a U shape and a 90 degree turn on the end will work.
2012 ML350 3.0 Turbo Diesel
Old 05-27-2012, 08:39 AM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Wheel Caps.
Hope this helps:
Gerry
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 05-27-2012, 10:09 AM
markmalin's Avatar
cool! I think I can rig something up. All else fails... I guess I can pull the wheels, then remove them and put them back on and lower the car to loosen the nut - but hopefully a little tool like this will allow me to pull them while the wheels are on the car
Originally Posted by 86 911 Targa View Post
Hope this helps:
Gerry
Old 05-27-2012, 05:15 PM
Retired Member
Charlie V's Avatar
You might have these..........
Pelican Parts - Product Information: PEL-PP905952
1982 911 SC Targa - Rosie....my Mistress. Rosewood Metallic on Dark Brown and Black. Long distance road warrior and canyon carver. A few mods - a little interior, some brakes, most suspension and all of the engine.
Old 05-27-2012, 09:55 PM
