Any tricks for removing axle nut?
Hi guys,
Starting in on my rear bearing/CV boot adventure. I bought a very long 1/2" breaker bar and a 1/2" 30mm socket. Holy cats is that bolt on there!! Any tricks for removing? The car is in gear, e-brake on, wheels on the ground. I wonder if I'll wind up breaking the joint on this breaker bar? Mark. |
Put a few feet of pipe on the bar, yes it's really on there that tight.
You need to get an extension on that breaker bar. I used my floor jack handle and it still took alot of pressure to break the nut free.
Never mind! I just went out and (carefully!) jumped on the end of the breaker bar and got both nuts to break loose :)
Mark. Quote:
I snapped a 1/2" breaker bar, moved onto a 3/4" with a 4' piece of black pipe from Home Depot to get enough leverage. That thing is on there TIGHT!!!
yup u need a 3/4
even then u need an extension |
Always remember to remove the cotter pin....
torquing to the correct value when re-assembling is also a challenge. You will need a length of pipe, depending on your weight, to reach proper torque. I believe it's ~340 ft-lbs.
Good luck.:) Anthony. |
You may want to cover the socket and extention with a heavy cloth/rug in case the socket breaks and goes airborne!
We put a ding in a SC fender trying to remove a spring plate adjustment bolt. |
I think a few others have just gone to a shop with a powerful impact wrench and had them break them loose then snug back up for the drive home where they could be removed without having to risk serious injury.
IMHO, a hand job is better than an air tool....
| All times are GMT -8. The time now is 12:51 AM. |
