markmalin's Avatar
Any tricks for removing axle nut?
Hi guys,
Starting in on my rear bearing/CV boot adventure. I bought a very long 1/2" breaker bar and a 1/2" 30mm socket. Holy cats is that bolt on there!! Any tricks for removing? The car is in gear, e-brake on, wheels on the ground. I wonder if I'll wind up breaking the joint on this breaker bar?
Mark.
Mark - New Glarus, WI
Old 05-27-2012, 08:04 PM
Scott R's Avatar
Put a few feet of pipe on the bar, yes it's really on there that tight.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 05-27-2012, 08:09 PM
You need to get an extension on that breaker bar. I used my floor jack handle and it still took alot of pressure to break the nut free.
"Charlie don't surf!"
Old 05-27-2012, 08:12 PM
markmalin's Avatar
Never mind! I just went out and (carefully!) jumped on the end of the breaker bar and got both nuts to break loose
Mark.
Originally Posted by markmalin View Post
Hi guys,
Mark.
Old 05-27-2012, 08:15 PM
I snapped a 1/2" breaker bar, moved onto a 3/4" with a 4' piece of black pipe from Home Depot to get enough leverage. That thing is on there TIGHT!!!
Buck
'88 Coupe, '87 Cab,
'88 535i sold, '19 GLC 300 DD
Warren Hall, gone but not forgotten
Old 05-27-2012, 08:24 PM
yup u need a 3/4
even then u need an extension
Jason
81 SC
97 328is
87 Jeep Comanche (RIP)
Old 05-27-2012, 08:40 PM
RETIRED
Joe Bob's Avatar
Always remember to remove the cotter pin....
2012 ML350 3.0 Turbo Diesel
Old 05-27-2012, 09:13 PM
torquing to the correct value when re-assembling is also a challenge. You will need a length of pipe, depending on your weight, to reach proper torque. I believe it's ~340 ft-lbs.
Old 05-27-2012, 10:50 PM
Originally Posted by 88911coupe View Post
I
Did the same when i tried undoing mine, as others here have said, those nuts realy are that tight, use a 3 quarter bar at least and a long piece of pipe, they will evenutualy let go, make sure your hands are clear of anything that may come in contact when it lets go.
Good luck.
Anthony.
Old 05-28-2012, 02:15 AM
You may want to cover the socket and extention with a heavy cloth/rug in case the socket breaks and goes airborne!
We put a ding in a SC fender trying to remove a spring plate adjustment bolt.
Old 05-28-2012, 05:15 AM
I think a few others have just gone to a shop with a powerful impact wrench and had them break them loose then snug back up for the drive home where they could be removed without having to risk serious injury.
Buck
'88 Coupe, '87 Cab,
Old 05-28-2012, 08:35 AM
RETIRED
Joe Bob's Avatar
IMHO, a hand job is better than an air tool....
Old 05-28-2012, 08:37 AM
