-   -   SC rear valence mod (RSR Style) help (http://forums.pelicanparts.com/porsche-911-technical-forum/681079-sc-rear-valence-mod-rsr-style-help.html)
sabeo.m 05-31-2012 06:23 PM
Guy's I'm going to be swapping out my single out Dansk for a dual center RSR type muffler, I understand that I either need to modify (cut) or completely remove the lower rear valence. If someone did this to their SC, any tips or pictures would help me out a lot. I did a search, but most of the pictures with this set up are on earlier 911's.
Regards.
Canada Kev 05-31-2012 06:32 PM
Not mine, but here's one that I got from here a while back. And you will have to modify or remove the rear valence.
http://forums.pelicanparts.com/uploa...1338514348.jpg
wildcat077 05-31-2012 07:28 PM
That actually looks pretty good on a G50 Carrera,i would be very curious to hear what it sounds like !
Cheers !
Phil
Mitch Leland 05-31-2012 08:18 PM
Rear valance...
Sabeo, I'm not sure if your rear valance is any different than my "84"? Rather than cutting on my original valance I bought a F/G reproduction from Raly8 that had no cut outs. I did the cut outs myself... I had the muffler mounted and I took a manila file folder and made a pattern of where the pipes came out. I used the valance mounting holes to locate the pattern. I have about 3/8" clearance around the pipes and so far I've had no burning of the paint.
The biggest problem you might get into is removing the philips head bolts from the valance. In my case I had case harden no. 6 mm philips cheese head bolts. I think there's 5-6 mounting bolts, 4 came out easily, but the other 2 had to be hammered on with a coal chisel. The problem is the aluminum bumper and the steel bolts which creates galvanic action.
http://forums.pelicanparts.com/uploa...1338520399.jpg
RarlyL8 05-31-2012 08:43 PM
Here is our custom valance with our S muffler and GT3 muffler.
http://forums.pelicanparts.com/uploa...1338522123.jpg
http://forums.pelicanparts.com/uploa...1338522185.jpg
sabeo.m 05-31-2012 11:15 PM
Excellent guy's, thanks for the help! I just checked out Rarelyl8...
will hung 06-01-2012 04:54 AM
I'd love to see more of this if you have them Kevin.
Canada Kev 06-01-2012 06:01 AM
Sorry, I don't. I just saw this one day in a thread here somewhere and thought I'd keep a copy of it because of the muffler tips or the bumper. I try to keep interesting pics for later reference. I can't even say which inmate this car belongs to.
javadog 06-01-2012 07:02 AM
There are three things you need to do. The first is to cut the hole (or holes) in the valance for the exhaust tips. The second thing is to extend the left side of the valence to fill in the original muffler hole. The third thing is to modify the left rear quarter panel extension, where the original exhasut hole was, to mirror what the right side looks like.
JR
toddu 06-01-2012 07:41 AM
Originally Posted by RarlyL8 (Post 6778839)
What is this decklid/wing combination? I dont' think I've ever seen a wing grafted on like that....
Todd
will hung 06-01-2012 09:16 AM
Dang. I'd like to see it from other angles. I have the same engine cover and Fuchs, but keep kicking around the idea of IROC bumpers. The fact that it has a sweet muffler helps.
sabeo.m 06-01-2012 12:00 PM
JR
Thanks JR, I think if I get the complete valence from rarelyl8 that will solve my problem.
sabeo.m 06-01-2012 12:03 PM
Guy's, I might just remove the valence and leave it be... I found this picture of a SC with no lower valence. I think I can get use to that set up until I buy an aftermarket one to fill with holes! I don't want to modify my factory valence... RSR muffler on its way!!
http://img.tapatalk.com/a6936893-11d9-980b.jpg
brendon 06-01-2012 04:03 PM
Mmmmmmmmmm. SCRS!
Where did you find that picture? I need a copy.
sabeo.m 06-01-2012 04:24 PM
Originally Posted by brendon (Post 6780238)
Mmmmmmmmmm. SCRS!
I found the photo right here, random 911 picture thread. Page 477
sabeo.m 06-13-2012 12:48 PM
Got it on! I cut the center valence, muffler fits perfect. I'm glad I did this swap, this muffler sounds awesome with my SSI's! Only thing to do is touch up the valence with touch up paint.
http://img.tapatalk.com/6c58d528-ee0b-2b96.jpg
http://img.tapatalk.com/6c58d528-ee15-cfa6.jpg
http://img.tapatalk.com/6c58d528-ee27-e70d.jpg
http://img.tapatalk.com/6c58d528-ee39-f849.jpg
KTL 06-13-2012 01:52 PM
Your license plate sticker is expired...... :D
Just watch your ankles when walking around the car. Those tailpipes look as dangerous as the tow hooks on my racecar that I constantly whack myself on!
sabeo.m 06-13-2012 02:06 PM
LOL, new sticker on the way! Yup pipes are a bit long...
Guardsred911 02-15-2013 09:24 AM
sabaeo.m,
Any issues with scorching the bumperette's with your set up?
Ian Comerford 02-15-2013 02:25 PM
I did this on my car when I got a GT3 style box. I bought a used valance and cut the right hand end off it after some measuring. I then welded it onto the left hand side of my existing one, the shape, radius etc is perfect and once painted it looks like a factory fit. Only thing left to do was cut out a bit of the centre section for the new pipes.
Easy!
Ian
