j911brick's Avatar
AAR Specifications
I did a search and couldn't find what I was looking for.
A few weeks ago I was diagnosing a car and decided to to check the AAR. Then I checked a couple more I had laying around. They all seems to test at about 16 ohms. But if I recall that was about half of what they should have been. I also seem to recall they were not closing (or opening- I forget which) all the way.
Is this pretty much unacceptable? Is there a way to fix these things? Looks like they were not designed to come apart (but since when has that ever stopped us)?
james
www.gruppe9autowerks.com
Its not how fast you go...its how you go fast
Old 06-01-2012, 07:56 PM
Scott R's Avatar
They come apart, drill the rivets. However they are externally adjustable as well, just remove the metal plug, it works like adjusting a WUR. Take measurements before you adjust with a caliper.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-01-2012, 08:29 PM
AAR......Bosch number
James,
Please post the number on the AAR. I might be able to furnish you with some data. Keep us posted.
Tony
Old 06-01-2012, 08:48 PM
j911brick's Avatar
Thanks Scott. I figured it was something like that. What do you replace the rivets with?
james
Old 06-01-2012, 09:24 PM
j911brick's Avatar
Originally Posted by boyt911sc View Post
James,
Tony
It was a few weeks ago and now I'm not sure what I dd with the spares. I'll let you know when I find one. I do know the ones I tested were off a 2.7S, 3.0 carrera, and '79 SC, and maybe a '82 930.
james
Old 06-01-2012, 09:26 PM
Scott R's Avatar
Just some small nuts and bolts. Somewhere there is a thread from way back with a guy that rebuilt the heating element.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 06-01-2012, 09:54 PM
James,
The Bosch numbers should be something like these.....0-280-140-???. The last three (3) digits would identify a specific Bosch AAR.
Tony
Old 06-01-2012, 10:00 PM
j911brick's Avatar
I'll see if I can't find it.
james
Old 06-01-2012, 10:24 PM
