Spark Plug Ends
Ok, this is going to sound like a stupid question, but i can't figure this out for the life of me. I've purchased new plug ends (the boots that go over the spark plugs themselves) from our host. I need to make up my own plug wires for my twin plug motor project. However I can not figure out how the actual wire is supposed to connect to these, Inside the boot is a metal piece that has a hole in the middle, the hole is to big for the conductor, and there is no way to put the wire into the boot that will not have the wire just fall out. Can anyone who has made up their own wires shed some light on this for me.
83 911 Production Cab #10
![]() Take one of your and unscrew the end and you'll see how the end piece
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
My old Beru without the spark plug boot
Ok. But i cant find any place that sells thosescrew in wire ends. Remember i am making custom length wires with hei coil ends for my dual plug setup.
Schleprock
The screw end terminal does have a Porsche part number. Also can be found at your Mercedes Benz dealer
Need part number Beru male threaded terminal
Kevin L '86 Carrera "Larry" Last edited by KTL; 06-03-2012 at 09:23 AM.. |
911.609.310 from PP at $2.75 each.
But the Cripping tool that you need is $325 so getting a set done from some Pelican would be cheaper.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger Last edited by JJ 911SC; 06-03-2012 at 09:42 AM.. |
Maybe I should be selling my spark plug wire tool
Lorne M.
83 SC |
i found some threads where folks have made their own crimping tools. And did finally find a place where the ends could be procured, so i ordered 10 from them (allowing for some "losses" due to crimping tool fabrication.
