Conntrol Arm U-Tab. Are They All The Same?
Hi,
Trying to put together my front sway bar assembly. I have a sway bar that is similar to a Tarret product. I have found the U-Tab kit from Weltmiester here at Pelican, but I want to make sure that it will work. Thanks for any help. James |
Yes it will, but have it welded in and mount it so the openings are front to back.
Thanks for the help.
front to back? I think mine from oem '72 arms are opposite that. Seems logical that they be opposite as well as the rod will be moving inboard and outboard and not forward and back... If you lace them with the open part front to back you may run into interference from the heim joint, no?
-Michael |
| All times are GMT -8. The time now is 07:18 AM. |
