jamesjedi's Avatar
Conntrol Arm U-Tab. Are They All The Same?
Hi,
Trying to put together my front sway bar assembly. I have a sway bar that is similar to a Tarret product. I have found the U-Tab kit from Weltmiester here at Pelican, but I want to make sure that it will work.
Thanks for any help.
James
Old 06-03-2012, 02:18 PM
tobluforu's Avatar
Yes it will, but have it welded in and mount it so the openings are front to back.
Old 06-03-2012, 02:32 PM
jamesjedi's Avatar
Thanks for the help.
Old 06-03-2012, 05:47 PM
Less brakes, more gas!
euro911sc's Avatar
front to back? I think mine from oem '72 arms are opposite that. Seems logical that they be opposite as well as the rod will be moving inboard and outboard and not forward and back... If you lace them with the open part front to back you may run into interference from the heim joint, no?
-Michael
Michael
'82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah
'13 Cayenne GTS
Old 06-04-2012, 12:45 PM
