Ball joint check method
What is the best driveway (no hoist) method to check the condition of ball joints in a 911?
"Charlie don't surf!"
Old 06-04-2012, 12:23 PM
wannabee wannabee
WIL84911's Avatar
I thought the wheel shake method if bearings are good means ball joint problem.
99 C4 - (let's try this once more)
07 Cayman S - sold 11/17 (not the same)
84 Carrera - sold 3/16 (geez what have I done!)
Old 06-04-2012, 01:26 PM
Mo money = mo parts
I am assuming no hoist does not mean no jack. Get the wheel in the air. Find a large bar - 1.5' - 2' (2x4 could work), needs to be long enough for leverage from bar. Stick it under wheel, just beyond the inside edge of the tire. Lift the bar until the wheel starts to move. A bad ball joint will feel like...well....a loose joint. You may need a partner to lift while you watch. You can put your hands and 12 and 6 o'clock, but you need to distinguish a ball join from a bearing.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 06-04-2012, 01:32 PM
Does the control arm need to be jacked up as well or will a faulty ball joint present itself with the suspension hanging down?
Old 06-04-2012, 03:45 PM
tazzieman's Avatar
Possible with suspension hanging down but...
When you think of it , it doesn't become bad overnight. At what point does wear become apparent , and can the backyard tests be sensitive enough to feel it? At the click/knock/play stage it's obvious. If the rubber boot is torn or the car has a healthy number of miles (notwithstanding the fact it might have had a hard life at some point) I would be looking at replacement. Apart from getting the nut off , it's an easy job Then you'll be good for half a lifetime.
What's your situation?
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 06-05-2012, 05:29 PM
