Where to find a Shaft Coupler for a Zenith 40 TIN?
Hello all,
I've got a broken shaft coupler on one of my Zenith 40 TIN carburetors on my 1971 T. Any suggestions on where to start looking for one? I'm guessing the Weber shaft coupler is not the same even though they look identical in pictures. Any help would be greatly appreciated. :-Dan Edwards 503.949.9919 |
Hell Belcho
try 356 carburetor rescue. index
good people and have kicked ass above and beyond the call of duty for me in the past.
Saved by the buoyancy of citrus. |
Senior Advisor
i used a webber coupler, had to drill it out and drill out the set screw but it does work
08 Cayenne Turbo |
Thanks for the super fast replies guys....
...I'll give 'em both a try.
If there are any additional suggestions, I'd love to hear them! :-Dan Edwards p.s. Can anyone confirm that the Weber part will or will not fit? |
A Weber shaft coupling can work (Pierce Manifolds has them) but be careful when enlarging the bores, if the resizing from 5mm to 8mm isn't performed carefully then there will be a side load which will cause the shafts to hang-up due to friction. I recommend the enlargement be performed on a lathe. Otherwise try buying a throttle body to salvage these couplings; they are otherwise unavailable unless there is a savager on eBay that offers them.
This seems to be a common failure of the Zeniths.
Paul Abbott Weber service specialist www.PerformanceOriented.com |
Thanks James.....
Thanks Paul....
Thanks again--you all are super helpful!! :-Dan Edwards |
There are quite a few commercially available shaft couplings that will do this job and the 'beam' type coupling is probably the most suitable unless originality is important.
This type of coupling is available in either Aluminium or Stainless Steel. Ruland Zero Backlash Flexible Couplings: One Piece Clamp Four Beam MWC; Aluminum; Metric Ruland Zero Backlash Flexible Couplings: One Piece Clamp Four Beam MWC; Stainless Steel; Metric There are other manufacturers who also have extensive catalogues. Flexible Beam Shaft Couplings - RCS, RCL, MWS, MST, MSX on The Precision Alliance This one may do the job but could be available at a better price if you dig around. http://www.rpmechatronics.co.uk/shop/products.php?2823&cPath=27_172_291_293 Last edited by chris_seven; 06-05-2012 at 11:15 PM.. |
