84 Carrera
Hidriver's Avatar
Fried DME relay solved
I recently posted my strange problem of frying 2 DME relays as I was driving my 84 Carrera. I appreciate all the tips ad advice. I am back on the road and the problem appears to be resolved. The problem was an indirect result no having no O2 sensor. The leads that the o2 sensor are normally would connect to were loose and tucked away back near the coil for who knows how long. When I recently had the 3 sensors replaced in that area the movement bumped the O2 connectors closer to the frame, and one day as I hit the gas hard it grounded. One of the 2 pins has constant 12v(i believe the O2 sensor heater). When it grounded it took 12v to the 30 amp DMe relay at pin 87B and cooked it immediately.
Ive since taped it off and everything is fine and running well. This afternoon I will install a whole new O2 sensor. The car runs well now, curious to see how the sensor affects things since it sounds like its an important part of the system
Thanks friends
Old 06-07-2012, 10:55 AM
Diss Member
Quicksilver's Avatar
Just a happy thing that it didn't fry the DME!
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 06-07-2012, 11:01 AM
Chain fence eating turbo
I thought you found that in your first thread?
Good discovery. Lucky you didn't have a fire and lose the car over the PO's doings.
Old 06-07-2012, 06:40 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Thanks friends
You should give your original thread (Fried DME relay.. twice) some closure by posting the above.
Who Will Live... Will See
Old 06-07-2012, 08:12 PM
S ECU Repair's Avatar
Good find!
Specialized ECU Repair
Porsche Bosch Motronic DME Specialists
Free DME Testing for Pelican Parts Members
www.ECUdoctors.com
1-800-328-1425
Old 06-08-2012, 08:12 AM
kodioneill's Avatar
Have to file that one in the archives. Nice job, thanks for posting the repair.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-08-2012, 11:48 AM
