Packy's Avatar
Broken Exhaust Stud tool- any lenders? Irvine, SoCal, LA, Orange?
Can anyone PLEASE please please please lend me an exhaust stud removal tool found here?
I have four broken studs I need to change out and I would prefer not to spend $270 on a fancy anodized tool I'm not going to use that much.
I would be extremely appreciative. If you need an exchange or something until I return it, I can give you one of my fuchs or something.
Thanks,
-P
(1) '77 Chassis and '79 SC 3.0 project car
(1) '79 911SC 3.0 Widebody SC
(1) '15 Ford F-150 4x4 3.5TT
Toluca Lake, CA
Old 06-06-2012, 12:22 PM
Mo money = mo parts
Packy - I would recommend that you buy a set of reverse drill bits. Use a punch to mark the center of the stud, then drill with a small reverse bit - smaller than the stud size. Once you remove some material from the center of the stud and the bit really begins to bite as it gets a little deeper, it may spin out. Most of corrosion that snapped the stud is above the surface of the block. You just need to take your time, use a variable speed drill and stop if you feel like you are too close to the block.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 06-06-2012, 01:39 PM
Obviously my 944 is much different than a 911 but here is how I pulled a broken exhaust stud from my 944. This was a difficult job because I had 2" of clearance from the manifold to the inner fender (barely room for my hands, let alone tools).
Anyway, the tool that I made from a piece of steel served the exact same purpose of the tool you have a link to - but mine cost me about $5 bucks.
Hope this helps a little.......Vern
Broken Exhaust Stud - Fixed :) Photos of My Repair
Old 06-06-2012, 01:48 PM
83 911 Production Cab #10
JJ 911SC's Avatar
Are all for broken flush?
Any pics?
Who Will Live... Will See
Old 06-06-2012, 03:26 PM
Packy's Avatar
2 flush, 1 kinda flush, 1 sticks out. I've done this before so I'm not too worried.
Toluca Lake, CA
Old 06-06-2012, 03:47 PM
JJ 911SC's Avatar
I kind of remember you from a previous thread so all you need is for a good Samaritan to pipe up...
Old 06-06-2012, 04:16 PM
Packy's Avatar
Yeah JJ, I remember talking to you too. That was last time I lived in NorCal and Tony helped out. I think I found someone local here in SoCal this time.
Thanks again. This board is awesome and the people are definitely a big help.
Toluca Lake, CA
Old 06-06-2012, 04:27 PM
Packy's Avatar
Scratch that. I found someone with the collet tool but I what I need is this tool Stomski Racing - Products
Toluca Lake, CA
Old 06-06-2012, 04:30 PM
Packy's Avatar
Nobody? Bump.
Toluca Lake, CA
Old 06-06-2012, 09:10 PM
911-32's Avatar
I have just managed to drillout 2 broken inlet studs without any guide. Scared me a bit to start with but if you take it slow, centre punch, then small bit working up to 6.8mm bit, its not too hard. I tapped out the remaining threads left in the hole and have 2 perfectly servicable inlet stud holes.
Its an option if you can't find the guide.
Old 06-07-2012, 04:56 AM
kodioneill's Avatar
Use a die grinder to flatten the surface of the stud, center punch, use good quality drill, if you mess up the threads use Helicoil insert. Quite simple actually.
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 06-07-2012, 05:03 AM
Instead of center punch, if the stud is not broken off flush, I use a cutting disk on a dremel. Hold the drimel at 90 degrees to the face of the stud and cut a shallow slot in the face of the stud.
Turn 180 and cut another slot. Looks like an X. Drill where the cut slots intersect. Gives you a nice, clean center hole. Works for me.
Tennessee911
Old 06-07-2012, 11:16 AM
JJ 911SC's Avatar
Originally Posted by kodioneill View Post
... if you mess up the threads use Helicoil insert. Quite simple actually.
I did mess up and use Time-Sert and work very well, was my first tap ever ++ TIME-SERT Threaded inserts for stripped threads, threaded inserts, thread repair stripped sparkplug's, Ford sparkplug blowouts, threaded inserts threaded, repair stripped threads, stripped threads, inserts threaded inserts, Ford spark plug repair,
Old 06-07-2012, 01:48 PM
