removing seized spark plug
Hi friends
Number 1 spark plug 'may' be seized or may not. I've asked around and I seem to have two schools of thought on what the worst case scenario would be, which would follow from the threads being crossed/pulled. A couple of mechanics have advised that should the threads be pulled that they would helicoil the head and that any aluminium particles that don't get removed will be fine - i.e. won't damage the heads or turbos. Another two mechanics have advised that due to the foreign matter created by the helicoil going into the heads that a top end would need to be done. What I want to know from the expert is - which is right? Do the heads really need to be opened up just to fix a seized spark plug, or could a helicoil be done safely with most of the particles removed, with remaining particles not being a concern? Thank you! |
a helicoil is the last thing i would use. a timesert is the way to go. Home page. use a considerable amount of white grease on the tap to catch most of the chips. #1 on a 930 isn't the easiest one to fix with the engine in place.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 06-18-2012 at 04:05 AM.. |
Thanks John. My main concern is the issue of cleaning up what falls into the head - what are your views on that? Would small amounts of aluminum cause issues?
Chain fence eating turbo
The grease is to keep shavings from going in.
i've done lots of them and no problems. a few tiny aluminum bits are not going to do any damage, as long as there's not a big pile of them. they'll be out the exhaust port real quick. turn the engine over a couple times by hand to be sure nothing is between piston and head before firing it up.
Thanks again that's good to know. Just to clarify its a turbo (930).
Banned
Any particles that exit the exhaust port will then hit the turbine impellor and it doesn't take much to tear-up those blades. . .
If the plus is still in the head & you can start the engine, start & warm up the engine. This will swell the head & loosen the plus. every little bit helps
Tom
68 Beetle 68 to 72 sold 72 911T Nov 71 to present P/U @ factory Nov 19. Car was gift to myself for surviving the army 67 VW split window 74 to 76 sold 81 VW caddy 81 to present |
