Nor Cal Treffen
Vin tag near smugglers box
Hi, is the stamped vin number supposed to be on a raised area like the one in the picture or on flat metal? Do not mistake the rust around the stamped area for welding it is just corrosion. I just a wire wheel to it to try and clean it up.
Thank you for you help! ![]()
Raised as you have it there...
Björn '76 911 Carrera 3.0 Targa '69 911 Outlaw '99 996 C2 |
Nor Cal Treffen
I found this number under the dash pad below the radio, can anyone decode it for me?
1292308 Thanks, Mike |
Nor Cal Treffen
Thank you Bjorn, I appreciate your help.
ROW '78 911 Targa
What year?
I have a stamped number by the smugglers box and the riveted panel by the fender on my '78 |
JR |
1292308 is broken down like this.
1 is a production body (0 would be a replacement chassis) 2 is for a Karmann produced body (0 is a Porsche coupe, 1 is a Targa, and 3 is Karmann 914/6) 9 is the model year of 1969 2308 is the sequential serial number for this body. The Karmann bodies also have a number sequence stamped in the rear tunnel opening, although I have never seen this number personally.
Brian '73 Carrera RS '71 911S coupe 'Patrick' '16 Cayman GT4 '91 C4 coupe |
