Need to Extend O2 Sensor Wire
I need to splice an extension wire into my O2 sensor since I installed SSI's on my SC. One of teh guys called for Mil-Spec wire but sourcing seems to be a challenge. Anybod have wire that might fit the bill? How about a heat wrap that I can use to cover the 6 inches exposed by the heat exchangers?
Any help or sources would be appreciated. Thanks! |
Interesting perspective crimp v. solder of O2 senor leads here:
http://forums.pelicanparts.com/porsche-911-technical-forum/682274-o2-sensor-extension-ssi-install.html |
Thanks! ProWire set me up!
I went and priced the Bosch O2 sensor and the lead wire it came with was about 2 inches long. Not sure which version comes with the long lead. The version of the Bosch O2 sensor I priced came with a crimped connector.
| All times are GMT -8. The time now is 02:49 AM. |
