-   -   Which Cat Bypass Pipe? (http://forums.pelicanparts.com/porsche-911-technical-forum/683018-cat-bypass-pipe.html)
Onefastman 06-11-2012 12:34 PM
I am getting ready to buy a bypass pipe for my 3.2 and was wondering if there was any reason to go with a more expensive brand over OBX.
Any thoughts?
OBX CAT DELETE 75-89 PORSCHE 911 2.7L 3.0L 3.2L | eBay
KNS 06-11-2012 01:03 PM
I was looking for something quiet. I went with the M&K pre muffler because it does have some "muffling" properties. Along with my stock exhaust I've got a pretty quiet, low-key car.
Andy911sc 06-11-2012 01:05 PM
also interested in thoughts on this
gtc 06-11-2012 01:14 PM
The OBX stuff usually doesn't look so nice from the inside. Their collectors/junctions are poorly made. My fabspeed was much nicer, and the M&Ks I've seen look great as well (the M&K was not available when I bought the Fabspeed). A lot of people gripe about the Fabspeed taking the O2 signal from only one cylinder bank, but I don't think it's really that big of a deal. Mine worked fine.
Onefastman 06-11-2012 01:26 PM
My previous 3.2 had a Dansk sport one in two out.
If I ran a bypass (as opposed to a premuffler) and a stock one in one out exhaust how do you think the two would compare?
gtc 06-11-2012 01:42 PM
I think the cat + dansk sport would be louder than a bypass + stock muffler.
Hydrocket 06-11-2012 02:33 PM
I suppose it depends. I know some of the older OBX stuff wasn't as nice, but their recent stuff is quite good. And the price is more than fair. I've handled one of those OBX pipes and the quality seemed perfectly fine.
I'd personally run an OBX on my car without worry.
Jesse16 06-11-2012 02:34 PM
I have the M&K Bypass from our host, nicely made and not very expensive. My car is louder, would probably have gone with the pre-muffler if chance to do again. Ben at M&K said both were similar loudness wise so ?? why does he sell both. I went with the less expensive option.
Went in easy.
Dublinoh 06-11-2012 03:28 PM
This was my preference also with a M&K one in/two out muffler. Before I had a gutted cat that sounded metallic and loud to the level that I capped the drivers side exhaust. Now run both sides open with the pre muffler, not too loud but still sporty.
McLovin 06-11-2012 03:32 PM
I like the factory Euro premuffler.
Oh Haha 06-11-2012 03:35 PM
+1
This in addition to my Flo-Pro 1in/1out muffler makes great sounds.:D
mclmk8d 06-11-2012 03:37 PM
I also have an M&K per muffler with an M&K oNe-in two-out GT3 exhaust. Pretty loud but I love the rumble
gamin 06-11-2012 03:52 PM
M&K pre muffler and stock muffler on the 88. A little rumble and nice sound. Not too loud. But I'm an old guy and don't like loud noises anymore. And I never listen to the radio in the Porsches.
suprxman 06-11-2012 04:01 PM
Obx
I bought an OBX last year and it fit with no problems and was nicely polished.
Cost $89.00. Installed a new O2 sensor.
If it doesnt last I'll re-weld it.
Hooked to a Bursch muffler and all sounds great.
I'm well pleased considering the price difference.
IHMO for what it's worth.
Aust87Carrera 07-19-2012 04:33 AM
All this talk about bypass's - I decided I'd buy one. I then worked out I should get a proper jack support and while I'm at it a new 02....$$.
After buying all the goods and removing the Cat - I discovered the guts had been removed anyway. So the job came down to cosmetics and a fun hour tinkering with the car.
The package was wonderfully boxed - thanks PP
Some tips:
1. The Fab Speed bypass comes with gaskets and bolts/nuts - the bolts are a different hardness to OEM - not sure it matters but the length of the bolts do and 3 to 4 thread lengths to short (I'll replace the bolts when I fix the rocker gaskets/leak).
2. Remove the wheel (LR) - I didn't to start with and by the time I mucked around maneuvering myself to get a swing at some of the bolts....I simply came to the conclusion to remove the wheel anyway.
3. Consider an oil change (and rocker gasket) while your at it, with the cat out of the way things are easy to get to.
I have the following pictures.
http://forums.pelicanparts.com/uploa...1342696251.jpg
http://forums.pelicanparts.com/uploa...1342696303.jpg
http://forums.pelicanparts.com/uploa...1342696348.jpg
http://forums.pelicanparts.com/uploa...1342696386.jpg
http://forums.pelicanparts.com/uploa...1342696425.jpg
http://forums.pelicanparts.com/uploa...1342696459.jpg
http://forums.pelicanparts.com/uploa...1342696490.jpghttp://forums.pelicanparts.com/uploa...1342696580.jpg
nineball 07-19-2012 08:44 AM
dansk pre-muffler, stock muffler. sounds a little beefier under 2k, above it sounds like normal.
http://i15.photobucket.com/albums/a3...e/IMG_0319.jpg
mb911 07-19-2012 09:00 AM
The one thing I can tell you for sure is only wish We could sell our bypasses and premufflers in the $89 range. We run off of a $60 an hour scale which is way light by todays fab standards and it takes waay longer then an hour to produce a part but thats what you get when you build them by hand and TIG weld them versus stamped and MIG welded.
Arne2 07-19-2012 09:02 AM
Same setup on mine, except my pre-muffler is an M&K. Pretty subtle sound, IMO. In fact, maybe too subtle. I'm still thinking about what might replace my stock muffler that might improve the sound but not be too loud for the neighbors and wife.
Joe Bob 07-19-2012 09:21 AM
Pulling the old cat and knocking out the catalyst is a lot cheaper option. It always amazes me how much people pay for 'Porsche' exhaust systems.
Arne2 07-19-2012 09:37 AM
A pre-muffler or bypass has the advantage of being reversible, should that ever be desired.
